This script only works on Mesh Faces. How to add Poly Faces? Unfortunately, I don’t know coding, I will be grateful if you could help me. Thank you!
macroScript AlignWorkplaneToFaceSelection category:"csTools" tooltip:"AlignWorkplaneToFaceSelection"
macros.run "csTools" "RemoveWorkPlane"
fn placeGridOnSelectedFace = (
local o = selection[1]
local omesh = o.mesh
local totalPos = [0,0,0]
local totalNormal = [0,0,0]
local selFaces = omesh.selectedFaces
if selFaces.count > 0 then (
for fc in selFaces do (
totalPos = totalPos + (meshop.getFaceCenter omesh fc.index)
totalNormal = totalNormal + (meshop.getFaceRNormals omesh fc.index)[1]
local center = totalPos/selFaces.count
local normal = totalNormal/selFaces.count
local selVerts = ((meshop.GetVertsUsingFace omesh selFaces) as array)
local firstEdge = normalize((meshop.getVert omesh selVerts[2]) - (meshop.getVert omesh selVerts[1]))
local xaxis = cross normal firstEdge
local yaxis = cross normal xaxis
local gridTm = (matrix3 (normalize xaxis) (normalize yaxis) normal center)
local worldTM = gridTm*o.transform
global workplane = (grid name:"workPlane" grid:10.0)
format "-- Genrating WorkPlane.\n"
workplane.width = workplane.length = (distance o.min o.max)
workplane.transform = worldTM
local tmpSelection = (selection as array)
select workplane
max activate grid object
select tmpSelection
toolmode.commandmode = #ROTATE
toolMode.coordsys #grid
toolmode.commandmode = #USCALE
toolmode.commandmode = #MOVE
else(
messagebox "Select face(s) on an object"
if selection.count == 1 and (canConvertTo selection[1] editable_mesh) == true then (
placeGridOnSelectedFace()
else(
messagebox "Select a Face on a Mesh"
I think should change these pieces to “Poly.” but … not working polyOp/opoly
omesh.selectedFaces
Paid script that works with Poly and Mesh objects:miauu's Work Plane.
It does work with polys, no need to change anything in the script.
But sometimes script throws an exception, not sure why...
As a workaround I just detach problematic polygon(s), align grid and attach them back.
