Create Named Selection Set for Edit Poly Modifier
By Ewok · 2012-04-25
Hi
I'm able to create a named selection set for an Editable Poly:
k = #{1..3, 5..7}
appendSubSelSet "SelSet01"
$.Faces["SelSet01"] = k
But I'm completely lost when trying to do the same thing for an Edit poly Modifier.
Does anyone have an idea how to do this?
john lanius
Does anyone know the maxscript for adding selected objects to an already created selection set. I can make a selection set via maxscript, but if i use maxscript to try and add more objects to the already created script, then it just replaces the objects in the selection set. Any suggestions on how to accomplish this with maxscript would be helpful.
Thanks.
Reply to john lanius
Panteleev Sergey
join selectionSet node with current selection and replace old selection set
NamedSelectionSetManager.ReplaceNamedSelSetByName (join (selection as array) selectionSets[#mySet]) "mySet"
Edit_Poly : Modifier
See "Edit_Poly : Modifier" topic in MaxScriptHelp
k = #{1..3, 5..7}
$.EditPoly.Select #Face k
$.EditPoly.SetEPolySelLevel #Face
Thank you barigazy,
the code does select the faces, but unfortunately, it doesn't create a Named Selection Set as the Editable Poly code does.
What I'm looking for is the Edit_Poly equivalent for
that tells the newly created Named Selection Set "SelSet01" what it contains.
I just can't figure out by what to replace
$.Faces
