Create file *.ifl
By manvelarz · 2007-12-02
Hello
I have a problem and that there is nothing written in support of maxscript, I think that is the case for the asking here.
I need to create *. ifl of a sequence that already exists, and I need to do with the script.
The command help ¨ ifl ¨ tells me that there is something, but nothing more.
Please help, I know that there are many people here who know a lot of maxscript
sorry for my bad English
thank you
Arda Kutlu
I do not know if there is a simpler solution but you can manually create an ifl file.
ifl file is nothing more than a simple text document which contains file names of the corresponding sequence in each line. Just try to open an ifl with notepad.
You see, since it is possible to create files and read/write data from these files, it is possible to create your own ifl.
look for flieStream values from maxscript help, and try to write data to a file from a previously created array which holds the names of the elements of image sequence.
this thread could be a start.
http://forums.cgsociety.org/showthread.php?f=98&t=561049
Cheers
Why dont use IFL_Manager :
UtilityPanel.OpenUtility IFL_Manager
