Hello!
I have a simple but important question to ask you. I'm studying a bit Maxscrpit and I have this problem:
I have a rollout with a button called "create & Move". I press the button and I create a sphere called Ball_01 to position [0,0,0]. All Ok...
Now, press the button again, I want create a new sphere (Ball_02) to [50,0,0] units along the axis X from a Ball_01. Press the button again and I create new sphere (Ball_03) to [100,0,0] along the axis X from Ball_01 and so on...
Similar to the loop in MaxScript Help:
for i = 1 to 5 do
box_copy = copy mybox
box_copy.pos = [i * 50, 0, 0]
I write this simple example, but I do not know how to go:
fn create Sp = (
s = Sphere()
s.name = uniquename "Ball_"
)--- end create _sphere
rollout test "Move Sphere"
button b "Create & Move"
on b pressed do create Sp
createdialog test
How To?
Thank you for your cooperation :)
Ciao
Michele71
Comments (7)
Wow, I still have much to learn!
Thanks so much for your note Anubis! :)
Now I will take your example to other studies of scripts. Thanks again!!
Glad I helped. Allow me to propose one improvement to the code.
In fact, because ".pos[1]" is sinunim to ".pos.x", ".pos[2]" is equal to ".pos.y", and ".pos[3]" is the same as ".pos.z", so you can use your radiobuttons index and...
Yes Anubis, yuor explanation is clear and linear.
In fact, I could not understand this part: allBalls[allBalls.count] but I now understand! I tried your advice and everything works great I have replaced the "50" with a .value so that I can used a spinner to move the ball in the axes and I also added one radiobuttons to choose the axes xy and z:
fn a b =(
allBalls = $Ball_* as array
s = Sphere name:(uniqueName "Ball_")
)--end a b
radiobuttons ra1 "Choose Axis" labels:#("x","y","z")
button b "Create Object"
spinner sp1 "Move object = " range:[-1000,1000,0] type:#integer
on b pressed do
a b
if allBalls.count > 0 do
if ra1.state == 1 then s.pos.x = allBalls[allBalls.count].pos.x + sp1.value
else if ra1.state == 2 then s.pos.y = allBalls[allBalls.count].pos.y + sp1.value
else if ra1.state == 3 then s.pos.z = allBalls[allBalls.count].pos.z + sp1.value
createdialog test
Truly a great big thank!! :)
Also you can use index multyplayer as in the MaxScript Help example, ie:
Well, at the beginning I just collect as array all objects which names start with "Ball_". Then create a new shpere with unique name "Ball_" and after that check if my array (allBalls) is not empty. So if its empty that mean this is the first sphere created and dont need to be moved by X. Else - this "allBalls[allBalls.count]" found last item in the array named allBalls and asign its position X + 50 to the new created sphere position X. I hope my explanation is clear :)
Anubis I want to give you a big kiss!
And the right solution to my problem :)
If I am not disturbing you, can you give me an explanation of your solution. I want to understand...
A big thank!
try this: on b pressed do (
try this:
