Crack Geometry Script
By kogden · 2009-03-30
Hi!
First time post here, and a first attempt at a script :D
So everyone is aware, I'm a fx artist and want to learn a bit of max script so it can speed my work flow up a little :). At the moment i am not wanting to make full blown tools for a team, just little things for myself.
Also with this script i got everything out of the maxscript help docs, not from tuts or other scripts :)
I got the idea from other scripts out there like MBFacture and the plug-in called Rayfire. both very cool and very useful tools!
This is my first attempt at any sort of script and is basically very buggy :(. but it was more of an exercise in how for loops work...
Anyways thought i might just post it so people could give me some feedback on it!
Again this is my very first attempt at doing a script, so please be gentle!
Cheers Kieran.
[blockcode]
Created by Kieran Ogden-Brunell March 2009
This script should break a selected object into chunks
Good for stone/rock debris
--FOR LATER REVISION--
______________________
- Pick button for object
-List box for multi objects
-bounding box function to drive crack plane sizes (currently this is a hardcoded value of 120 in scene size)
-dialog box for user enable cancel or continue
-save "tick" option, so scene is saved before calculation
-tick option to keep orginal mesh
-Iteration feature to run the simulation over the first pass cracks
- minimum size threshold for breaking on first pass and iteration
_______________________
KNOW ISSUE"S
-Crash's MAX randomly if used to much.
-Crash's MAX if gc() is used
-Process breaks if the crack planes are too small compared to the user object
rollout kobCracks "Crack Geometry"
edittext _oName "Name" fieldWidth: 160 height:16
spinner _pAmount "Crack Density" type:#integer range:[1,20,5]
spinner _pSegs "Crack Detail" type:#integer range:[3,12,7]
spinner _pNoiseHieght "Crack Shear" range:[0,85,55]
spinner _pSmoothAmount "Internal Smooth" range:[0,90,24]
-- checkbox _keepOrgObj "Keep Original Object"
-- on _keepOrgObj changed theState do
-- copy $
-- hide $
-- messagebox ("Your orginal object has been copied and hidden! Please select mesh " )
button _create "Create Cracks" width:150 height:50 tooltip:"Crack Object!"--this should eventually name the seperate chunks!!!!!!!
on _create pressed do
if _pAmount.value >= 15 then messagebox "WARNING: Could become unstable!" --warns if you have too many planes need a cancel or continue dialog
DisableSceneRedraw
_firstPlane = null
for j = 1 to _pAmount.value do -- created the rest of the planes need to complete the spinners value
p= (plane())--creates plane from the exposed spinner's
p.name = uniquename "cutPlanes"
if (j == 1) then _firstPlane = p
p.length = 150
p.width = 150
p.lengthsegs = _pSegs.value
p.widthsegs =_pSegs.value
p.wirecolor = [random 0 255,random 0 255,random 0 255]
addModifier p (Noisemodifier()) --adding noise modifier to plane
p.modifiers[#Noise].seed = random 1 1000
p.modifiers[#Noise].scale = random 45 85
p.modifiers[#Noise].fractal = on
p.modifiers[#Noise].strength = [(random 0.0 1),(random 0.0 1),(random _pNoiseHieght.value (_pNoiseHieght.value+5))]
addModifier p (smooth()) --adding smooth modifier to plane
p.modifiers[#smooth].autosmooth = on
p.modifiers[#smooth].threshold = _pSmoothAmount.value
rotate p (eulerAngles (random 0 360) (random 0 360) (random 0 360)) --rotates planes in "for" a random value from 0 to 360 degrees
convertTo p (Editable_Poly) --convert to edit poly
if (j > 1) then polyop.attach _firstPlane p
-- this is the pro cutter section currently works with one cut
a = _firstPlane
c = $
ProCutter.CreateCutter #(a) 1 True True False True True
ProCutter.AddStocks a #(c) 1 1
Delete a
-- Rename objects to the name specified
all = $cutPlanes*
all.name = uniquename _oName.text
EnableSceneRedraw()
-- gc()
button _HowToBox "Info" tooltip:"Info"
on _HowToBox pressed do
messagebox "Create an Object or use an existing prop. \n Select the mesh you want to crack. \nPress Create Cracks to Run!"
button _aboutBox "About" tooltip:"About" --align:#right
on _aboutBox pressed do
messagebox "This script creates cracks in selected objects\nCreated by Kieran Ogden-Brunell 2009"
createdialog kobCracks width:220 height:220
gorillamilk
How do I run this, install this? What do I do with this code? Instructions for non-application developers would be nice! :) Because I'm sure NOT a programmer.
blackfoxeye
Hi Kieran,Thank you very
Hi Kieran,
Thank you very much for reply. Now its working fine with max 9 & 2009.
And I appreciate, this is a really really great tool.
Its my fault, previously I was trying it with max 7.
Great work :) keep it up man.
BlackFoxEye
kogden
mmm firstly awesome a reply!
the only thing that really spring to mind is, are you using version 9 or above?? seems silly but thought i would ask. :)
I have updated the script slightly and have noticed substantial stability!
NOTE-the size and position of the object no longer matter!! yay! was easier then i thought.
Heres the script again!
[blockcode]
- List box for multi objects
- Bounding box function to drive crack plane sizes (currently this is a hard coded value of 120 in scene size)
- Dialog box for user enable cancel or continue
- Save "tick" option, so scene is saved before calculation
- Tick option to keep original mesh
- Iteration feature to run the simulation over the first pass cracks
- Minimum size threshold for breaking on first pass and iteration
KNOW ISSUE"S
- Crash's MAX randomly if used to much.
- Process breaks if the crack planes are too small compared to the user object
- Crash's the script if objects aren't "water tight"
- Crash's teh script if the object is too far from world zero.
- If the crack scripted is used on already cracked mesh, sometimes removes part of the orignal object.
spinner _pAmount "Crack Density" type:#integer range:[1,20,8]
spinner _pSegs "Crack Detail" type:#integer range:[10,30,20]
spinner _pNoiseHieght "Crack Shear" range:[0,120,55]
spinner _pSmoothAmount "Internal Smooth" range:[0,90,65]
-- create planes from the spinners value
DisableSceneRedraw
_firstPlane = null
X = $.max.x - $.min.x
Y = $.max.y - $.min.y
Z = $.max.z - $.min.z
maxDis = (amax X Y Z)* 1.2
p= (plane())
p.length = maxDis
p.width = maxDis
objPos = $.position
p.position = objPos
a = _firstPlane
c = $
Delete a
all = $cutPlanes*
EnableSceneRedraw()
button _howToBox "Info" tooltip:"Info"
on _howToBox pressed do
hope this helps!
Kieran
blackfoxeye
Hi Kieran,It seems really
Hi Kieran,
It seems really nice script. I tried to use it, but I am getting an error on line "ProCutter.CreateCutter #(a) 1 True True False True True"
And a popup message came with "Unknown property: "CreateCutter" in undefined".
So can you please tell me about this error?
BlackFoxEye
