Count materials of each loaded .mat file
By 3dwannab · 2016-01-23
This is probably very easy but what I want is to get an array of the number of materials inside a .mat file array.
What I have so far is:
--array of mat files
mat = #("F:\\3dwannab Maps_Corona.mat", "F:\\3dwannab Set_Corona.mat", "F:\Basic_Corona_Set.mat")
--loop setup to get the count
for i in 1 to mat.count do (
--for getting materials only count (I need this to count for each mat). I'm not sure how to do this.. At the moment this works for the last material in that above array.
for i in mat do matFile = loadTempMaterialLibrary i
materialsOnly = for i in matFile where superclassof i == material collect i
materialsOnly.count
3dwannab
One question
Lets say I've two arrays like so:
#("3dwannab Maps_Corona", "3dwannab Set_Corona", "Basic_Corona_Set", "Jakub_Cech_Corona_set", "Jeff_Patton_Paints_Corona_Set", "Siger_Corona_Set", "VisCorbel_Corona_Set", "VisCorbel_VRay_Set", "VizPark_Corona_Set")
#("6", "109", "20", "14", "11", "10", "79", "79", "5")
And I want to append each of their values to the corresponding mat like so:
New array should be:
#("3dwannab Maps_Corona 6", "3dwannab Set_Corona 109", "Basic_Corona_Set 20", "Jakub_Cech_Corona_set 14", "Jeff_Patton_Paints_Corona_Set 11", "Siger_Corona_Set 10", "VisCorbel_Corona_Set 79", "VisCorbel_VRay_Set 79", "VizPark_Corona_Set 5")
The MSX Array help doesn't show this (at least I can't see it) ;]
Reply to 3dwannab
Both arrays must have the same amount of elements.
	arr01 =	#("3dwannab Maps_Corona", "3dwannab Set_Corona", "Basic_Corona_Set", "Jakub_Cech_Corona_set", "Jeff_Patton_Paints_Corona_Set", "Siger_Corona_Set", "VisCorbel_Corona_Set", "VisCorbel_VRay_Set", "VizPark_Corona_Set")
	arr02 =	#("6", "109", "20", "14", "11", "10", "79", "79", "5")
	for i = 1 to arr01.count do arr01[i] += " " + arr02[i]
Reply to miauu
3dwannab
Great, thank you.
The method of my madness was I just wanted to display info in a listbox without the need for using .net for columns. See finished but not fully tested script. It creates teapots from the materials inside .mat files and puts them on teapots. I made it so I could manage my .mat files better and update the Materials when I needed to. It recurses through directories also.
The code Swordslayer gave me didn't work as intended:
for i in matFile where isKindOf i Material collect i
So I went with this instead which accurately gets all the Materials and Maps.
Would you know why this is the case here? I've commented in the script where this is.
See attached script and code below also.
3dwannab Materials in .mats to teapots in scene
v1.0 - 2016.01.25 - Initial Release
if rol_Mats2Scene != undefined do (destroyDialog rol_Mats2Scene)
rollout rol_Mats2Scene ".mat Library Scene Creation"
	local matCount_Arr = #()
	local mapCount_Arr = #()
	local matLibDir_Arr = #()
	local matLibFiles_Arr = #()
	-- change this to your directory, script uses recurise scanning so set it as the root folder if you wish, check the checkbox 'Recurse Directories'.
	local intialMLPath = "F:\\SS_3diT\\Textures & Materials\\Corona Materials Collection\\"
	label lbl_directory "Looking in Directory: " align:#left across:2
	label lbl_M2SPath intialMLPath align:#left offset:[-180,0]
	button btn_getDir "Choose Library Directory" align:#left across:3
	checkbox chk_recurseDir "Recurse Directories" align:#center checked:false
	button btn_update "Update" align:#right
	listBox ml_list items:#() height:15
	label lbl_usage "Double click .mat file to create Teapots with all its materials in the current scene"
	fn initialDirCheck = (
		if DoesFileExist intialMLPath == false then (
			matLibDir_Arr = GetDir #matlib + "\\"
		else (
			matLibDir_Arr = intialMLPath
	fn getMaxFiles_fn dir pattern = (
		if rol_Mats2Scene.chk_recurseDir.checked == true then (
			local dir1 = getDirectories (dir + "*")
			for d in dir1 do (
				join dir1 (getDirectories (d + "*"))
			local files = #()
			for f in dir1 do (
				join files (getFiles (f + pattern))
			appendIfUnique dir1 1 -- fix to get current folder too
			return files
		if rol_Mats2Scene.chk_recurseDir.checked == false then (
			files = (getFiles (dir + pattern))
			return files
	fn getMatsInfo_Arr = (
		matCount_Arr = for i in matLibFiles_Arr collect
			local matFile = loadTempMaterialLibrary i
			-- isKindOf didn't work as expected so I reverted to getting superclassof instead
			local materialsOnly = try(for i in matFile where superclassof i == material collect i)catch() --isKindOf i Material collect i
			if materialsOnly != undefined then materialsOnly.count else matCount_Arr = "UNKNOWN, Load plug-ins for"
	fn getMapsInfo_Arr = (
		mapCount_Arr = for i in matLibFiles_Arr collect
			local mapFile = loadTempMaterialLibrary i
			local mapsOnly = try(for i in mapFile where superclassof i != material collect i)catch() --isKindOf i Material collect i
			if mapsOnly != undefined then mapsOnly.count else mapCount_Arr = "UNKNOWN, Load plug-ins for"
	fn mainFN = (
		initialDirCheck()
		matLibFiles_Arr = getMaxFiles_fn matLibDir_Arr "\\*.mat"
		getMatsInfo_Arr()
		getMapsInfo_Arr()
		matsNames_Arr = for i in matLibFiles_Arr collect (getFilenameFile i)
		list2 = for i = 1 to matsNames_Arr.count do matsNames_Arr[i] += " | " + matCount_Arr[i] as string + " Material/s | " + mapCount_Arr[i] as string + " Texture Map/s"
		ml_list.items = matsNames_Arr
		lbl_M2SPath.text = matLibDir_Arr
	fn ResetViewports = (
		actionMan.executeAction 0 "40043" -- Selection: Select None
		viewport.ResetAllViews() --resets to Max Standard
		actionMan.executeAction 0 "331"  -- Tools: Zoom Extents All
		actionMan.executeAction 0 "311" --frames all viewports
		viewport.zoom .75 --fix to make perspective view appear closer
		viewport.setGridVisibility #all false --turns off all grids
		actionMan.executeAction 0 "40829" --show statistics
		completeredraw() --redraw the views
		--set max display colors (Choose #material or #object for either)
		displayColor.shaded = #material
		displayColor.wireframe = #object
	fn ResetViewportsForCoronaIRRender = (
		if (matchPattern (renderers.current as string) pattern:"Corona*") then (
			PersViewMatrix = viewport.getTM() -- Get perspective matrix3 (viewpoint)
			zoomAmount = .75 as float
			ViewCubeOps.Visibility = false
			actionMan.executeAction 0 "63547"  -- Views: Viewport Materials Display as Realistic with Maps
			viewport.setLayout #layout_3hb
			ViewPanelManager.SetSplitterBarPos 0 0.55
			ViewPanelManager.SetSplitterBarPos 1 0.65
			viewport.activeViewportEx 3
			viewport.setType #view_persp_user
			viewport.setTM PersViewMatrix -- Set the view stored above
			max zoomext sel
			viewport.zoom zoomAmount --fix to view appear closer
			actionMan.executeAction 0 "40406"  -- Views: Extended Views 3
			viewport.activeViewportEx 2
			max zoomext sel
			--actionMan.executeAction 0 "369"  -- Views: View Edged Faces Toggle
			actionMan.executeAction 0 "272"  -- Views: Wireframe / Smooth+Highlights Toggle
			viewport.activeViewportEx 1
			max zoomext sel
			viewport.setType #view_top
			max tool maximize ; max tool maximize -- hack to get the viewport to update outline
			viewport.activeViewportEx 2 -- return to perspective
			try(if (for i in cameras where superclassof i == Camera collect i).count == 1 then (
				viewport.setType #view_camera
			))catch()
			--#layout_1 | #layout_2v | #layout_2h | #layout_2ht | #layout_2hb | #layout_3vl | #layout_3vr | #layout_3ht | #layout_3hb | #layout_4 | #layout_4vl | #layout_4vr | #layout_4ht | #layout_4hb
			--#view_left | #view_right | #view_top | #view_bottom | #view_front | #view_back | #view_iso_user | #view_persp_user | #view_camera | #view_grid | #view_none | #view_spot | #view_shape
	on rol_Mats2Scene open do (
		initialDirCheck()
		lbl_M2SPath.text = intialMLPath
-- 		matLibDir_Arr = intialMLPath
		getMatsInfo_Arr()
		getMapsInfo_Arr()
	on rol_Mats2Scene close do (
-- 		intialMLPath = undefined
	on btn_getDir pressed do (
		matLibDir_Arr = getSavePath caption:"Choose .mat Library Directory or root Directory" initialDir:intialMLPath
		if matLibDir_Arr != undefined do (
			mainFN()
	on btn_update pressed do (
		mainFN()
	on chk_recurseDir changed state do (
		if state then (
			mainFN()
		) else (
			mainFN()
	on ml_list doubleClicked itm do	(
		if querybox "Do you create a new scene ?" title:"Create New Scene" beep:true
		then (
			actionMan.executeAction 0 "40004"  -- File: New Scene
			teaRadius = 10
			matFile = loadTempMaterialLibrary matLibFiles_Arr[itm]
			-- used for testing only
			-- matFile = loadTempMaterialLibrary "F:\\SS_3diT\\Textures & Materials\\Corona Materials Collection\\3dwannab Set\\3dwannab Set_Corona.mat"
			-- print matFile
			delete $Teapot* ; teapotsArr = for i in 1 to materialsOnly.count collect Teapot radius:teaRadius smooth:on segs:10 body:on handle:on spout:on lid:on mapcoords:on pos:[0,0,0] pos:[teaRadius*3*i,0,0]
			for i = 1 to materialsOnly.count do objects[i].material = materialsOnly[i]
			print ("Teapots created with " + materialsOnly.count as string + " material/s")
			ResetViewports()
			ResetViewportsForCoronaIRRender()
		else (
			teaRadius = 10
			-- print matFile
			select teapotsArr
			max zoomext sel
			max select none
createDialog rol_Mats2Scene 600 278 style:#(#style_titlebar,#style_sysmenu,#style_minimizebox)
Vojtech Cada
You almost had it :)
mat = #(@"F:\3dwannab Maps_Corona.mat", @"F:\3dwannab Set_Corona.mat", @"F:\Basic_Corona_Set.mat")
matCounts = for i in mat collect
	local materialsOnly = for i in matFile where isKindOf i Material collect i
	materialsOnly.count
Reply to Vojtech Cada
3dwannab
Thanks Swordslayer
I never used the while command so I came up with this method which doesn't get an array like yours but might come in useful in my quest to learn MXS.
mat = #("F:\3dwannab Maps_Corona.mat","F:\3dwannab Set_Corona.mat","F:\Basic_Corona_Set.mat")
while mat.count >= 1 do (
	print mat[1]
	matFile = loadTempMaterialLibrary mat[1]
	matCount = materialsOnly.count
	print matCount
	deleteItem mat 1
