If I shift-drag a selection of objects in the 3ds Max viewport, I create a copy of them that have the same animation controllers, user properties, linked hierarchy etc.
If I copy those objects with Maxscript, they are disconnected and most stuff is not copied. Is there a way to do this easily, like a "deepCopy" for objects? Or do I have to buffer and reapply all that stuff?
Cheers
Sweet, that was it! No collecting hierarchy, no buffering userProps and controllers, thanks Anubis. In fact that made 1 line out of my 24 lines of code
those are not needed or are
those node array lists are not needed or are they? what are they typically used for?
edit: ah nevermind, the maxOps just returns "OK" so i need the node list to access my copied objects, right :D?
yes ;)
maxOps.CloneNodes ?
maybe
can help?...
