Converts selection to verts or exits the object
By pedro · 2014-09-09
Hi guys,
I'm trying to make a script that basically converts whatever you have selected (faces, edges etc) to verts if you have something selected like a face or something.
But if you don't have nothing selected or are in vert mode it won't do anything, and will leave the object.
So far I have this.
macroScript ConvertToVertOrExit
category:"Pedro Scripts"
toolTip:"Converts Selection to verts or exits the object"
    try
        if (subobjectlevel >= 1) then
            macros.run "Editable Polygon Object" "EPoly_Convert_Sel_To_Vertex"
		if (subobjectlevel == 1) then
			subobjectLevel = 0
			clearSelection()
		if (subobjectlevel == 0) then
        if ( $ != undefined) then
            modPanel.setCurrentObject $
            subobjectLevel = 1
	catch()
Any help is appreciated.
I guess i need a code to see if ihave something selected.
Thanks!
Pedro
Try now.
pedro
Hey barigazy,
Thanks for replying.
Unfortunately it doesn't work. If you are on vert mode or don't have anything selected it won't leave the object.
Try this one. Supports Editable Poly object and Edit Poly modifier
if selection.count == 1 do
node = case classof selection[1] of
(PolyMeshObject): selection[1].modifiers[1]
(Editable_Poly): selection[1]
default: (undefined ; clearselection())
if node == undefined then messageBox "This object is not supported!" title:"Warning" beep:off else
array = #(#Edge,#Border,#Face,#Element)
if (e = finditem array (node.GetEPolySelLevel())) == 0 then clearselection() else
(node.convertSelection array[e] #Vertex ; subobjectLevel = 1)
