Well, a while ago I thought I had this problem sorted.. But it seems that the magical pony that is 3ds max has given me another curve ball.. Recently myself and my group discoed, that even though we set our units to 1m = 1 unit, things as such as obj exporters and function calls inside of maxscript (body.pos.z) on the other hand were using data that was 40x as large.. (we are using the build in .obj exporter in 3ds max) I could get the actual units through use of:
fn getFormated unFormated =
brokenUp = filterstring (units.formatValue unFormated) "m"
return brokenUp[1]
which this fixed both scale and position.. however.. it seemed to have broken rotation aswel.. Which is just dandy..
this is my old exporter for pos, rot, scl
format "\t\t<position> " to:currentFile
format "% " body.pos.x to:currentFile
format "% " body.pos.z to:currentFile
format "% " -body.pos.y to:currentFile
format "</position>\n" to:currentFile
format "\t\t<rotation> " to:currentFile
format "% " body.rotation.w to:currentFile
format "% " body.rotation.x to:currentFile
format "% " body.rotation.z to:currentFile
format "% " -body.rotation.y to:currentFile
format "</rotation>\n" to:currentFile
format "\t\t<scale> " to:currentFile
format "% " body.scale[1] to:currentFile
format "% " body.scale[3] to:currentFile
format "% " body.scale[2] to:currentFile
format "</scale>\n" to:currentFile
and this is the new, which exports correctly scaled data (with an exception to the now broken rotation)
frmtd = getFormated(body.pos.x)
format "% " frmtd to:currentFile
frmtd = getFormated(body.pos.z)
frmtd = getFormated(-body.pos.y)
frmtd = getFormated(body.scale[1])
frmtd = getFormated(body.scale[3])
frmtd = getFormated(body.scale[2])
is there some way to apply:
units.formatValue
to a x,y,z,w rotation???
Also u can use
xRot = obj[3][2][1].value
yRot = obj[3][2][2].value
zRot = obj[3][2][3].value
objRot = eulerAngles xRot yRot zRot
EulerToQuad objRot
ok, I tried that, unfortunately it produced the same results, heres one of the issues I was talking about:
(just if the immage isn't clear, the grey ends i circled are the purple parts in the 3ds max scene, they are rotated incorrectly but positioned correctly(to the best of my knollage)
http://i48.tinypic.com/20z6x5l.png
what I think is the issue is scaling.. I found out that I had to use units.formatValue for my rotation and scale the act of changing those has caused my rotation to break.. I believe that before it was rotated correctly, but due to my lack of sleep I will doubt anything :\ but you don't have my other code (in my engine) so assume that my engine is doing it correctly and it's the extraction of the data from 3ds max to my xml which is where the problem occurs.. another reason to assume is that before I found that scale issue and fixed it I ran extensive testing of rotation, scale and positioning which they all worked... I will re-run the tests, but I honestly can't read or concentrate, so ima hurt myself if I go on anymore.
just repeating.. I have had problems with scale!!! (the scl/pos is fixed now)
hopefully when I get up you've worked your magic once again.. your amazing
I used only this:
We have a euler to quat converter..,im,gonna try extracting quat data ur way tomorow, but I had to crash...
Why don't youtry to
Why don't you try to resetXform and place pivot at the objects center before you store data in XML.
max modify mode
with redraw off
local arr = for obj in objects where isKindOf obj GeometryClass and not isKindOf obj TargetObject collect
(ResetXForm obj) ; CenterPivot obj ; obj
convertToMesh arr ; free arr
--and try with formating
Are you try usin EulerToQuad method
See this topic under "Related Method"
