I am using the following script as a part of a level exporter for an OPENGL game
format "\t\t<position> " to:currentFile
format "% " body.pos.x to:currentFile
format "% " body.pos.z to:currentFile
format "% " -body.pos.y to:currentFile
format "</position>\n" to:currentFile
format "\t\t<rotation> " to:currentFile
format "% " body.rotation.x_rotation to:currentFile
format "% " body.rotation.z_rotation to:currentFile
format "% " -body.rotation.y_rotation to:currentFile
format "</rotation>\n" to:currentFile
format "\t\t<scale> " to:currentFile
format "% " body.scale[1] to:currentFile
format "% " body.scale[3] to:currentFile
format "% " body.scale[2] to:currentFile
format "</scale>\n" to:currentFile
but when i rotate the 3ds max scene, the XML once loaded into my opengl game will be slightly out in a weird way if the following axis (right hand system) are both non 0: xy, xyz
I believe it's because the rotation system in 3dsmax isn't simply a x, y, z it's an euclidean, x, y, z, w
but I attempt to read the doco and its just confusing...
is there anyway I can export X/Y/Z rotation from 3dsmax for an OpenGL game or do I need to include X/Y/Z/W?
Are you try with "quadToEuler2".Read this for more info
haha you always find stuff I sware to god I look for ages for.. But quad is better anyway because our system uses it, before i was converting the Vector3 into one, it was stupid, but I didn't know we were as that was another members work
I'm almost certain now that it's somthing to do with missing w, can sombody please just confirm?
Edit:
confirmed, to get full rotation from 3ds max you must use Quaternion's
