Convert string to float / array problem
By Rodman · 2012-11-01
Hello,
I want to convert a string which contains a formula but once i want to use it as a float, it doesn't work.
Look at my script to understand the problem :
the_array = #()
for t = 0 to 100 do (append the_array t)
-- replace tt in string by the_array[t]
formula = "(" + "cos((tt*2)*(180/pi))+tt" + ")"
tokens = filterString formula "tt" splitEmptyTokens:true
for i = 1 to tokens.count do
if tokens[i] == "" do
tokens[i] = "(the_array[t])"
formula = ""
formula += tokens[i]
x_matrix = bigMatrix 1 the_array.count
for t = 1 to the_array.count do
formula = formula as float
x_matrix[1][t] = formula -- I want to have formula = (cos((the_array[t]*2)*(180/pi))+the_array[t])
Comments (8)
just a fun idea, maybe...
but try it out anyway :)
fn buildFormula val = (
	local ss = stringStream ""
	format "cos((%*2)*(180/pi))+%" val val to:ss
	local result = ss as string
	free ss; result
fn proxyEval &strExpr &expCntrl = (
	if expCntrl.SetExpression strExpr then
	(expCntrl.Update(); expCntrl.value)
	else 0
the_array = for t = 0 to 100 collect t
exc = expression_controller()
formula = ""
	formula = buildFormula t
	proxyEval &formula &exc
p.s. - Most scripters not like
execute()
as it evaluate in the global scope, but if that not a problem for your script, then just use
format()
to build the string, but if that formula is unknown to the script, and you know only that it holds "tt" variable, then float expresion or float script can help.
Here is with float script:
fsc = float_script()
fsc.script = "cos((tt*2)*(180/pi))+tt"
fsc.addConstant "tt" 0
arr_results = #()
arr_results[100]  = 0
for t = 1 to 100 do
	fsc.SetConstant "tt" &t
	fsc.Update() -- eval expr.
	arr_results[t] = fsc.value
I got errors
I have errors when I execute it.
I can't understand your script. If you can tell me how it works it could help to solve the errors.
I want to use any mathematic formulas. And I think your script works for just 1.
By the way, thank you Master.
Reply to Rodman
well...
The main idea was to use controllers to evaluate your math expresion (instead of Execute() function), but if my code is too alien and can't debbug it yourself then just skip it for now and stick to using Execute().
>> "I want to use any mathematic formulas"
- Did you mean for example "((cos(X-D)/sin(Y+M))*(Z/E)^pi)+F"? Here is alot of variables.... lol :) if you made some inputbox where to type any formula, then should make as well some naming convension. For example if you use var T it should always mean Time, and so on. I think that the script controllers can helps you, as they allow to setup as much variables as you need (and with the var-names by your choice).
Reply to Rodman
and...
If i get correctly your goal, then searching for how to replace the char inside a string with float (or other type) value is a wrong direction.
Your math formula (as string or not) needs to get some value from anywhere anyway, right?
Maybe this very simple example made just for illustration will helps to sort your thought:
rollout test ""
	local X = 0, Y = 0
	spinner spnX "X:" range:[0,100,0]
	spinner spnY "Y:" range:[0,100,0]
	edittext txtFormula "Enter formula:"
	spinner spnResult "Result:" range:[-1000,1000,0]
	button btnEval "Evaluate"
	on spnX changed val do (X = val)
	on spnY changed val do (Y = val)
	on btnEval pressed do
		try(spnResult.value = execute txtFormula.text)
		catch(messageBox (getCurrentException()))
CreateDialog test
-- now if you type in the editText field some valid expressions like:
"(X + Y) * 2", "(X * Y) / 3" -- end so on...
-- that will work fine
-- but staffs like:
"bla-bla" -- lol ... no way :)
"(pi * F) / N" -- ever this looks good but...
-- our UI support just X and Y for input
-- F and N are Undefined (in that example)
cheers!
Reply to Rodman
Its possible to have some error as I not test the code, but I hope you get the idea.
Also really wonder, why you just not use the same variable name for your loop (ie TT):
formula = "cos((tt*2)*(180/pi))+tt"
for tt = 1 to 100 do execute(formula)
And if by reason you need to loop with other variable name, for example "For X = ... Do", then:
for x=1 to 100 do (tt=x; execute(formula))
The TT can be logal or global variable, is your choice.
So if you happy with Execute(), then that's all ;)
Garp
Look at execute()
It will tokenize and evaluate your string for you.
Reply to Garp
Rodman
Thanks for your help.I have
I have just found a solution :
the_array = #()
	the_value = the_array[t] as string
			tokens[i] = the_value
	formula = ""
	format "tokens is %\n" tokens
	formula = execute formula
	format "formula is %\n" formula
But as you can see my formula must have tt as a variable and I would like to put t only, but function like tan will not work with my script. Do you have an idea how to do it ?
