Convert materials in scene to VrayOverrideMtl
By Dean Punchard · 2017-10-31
I'm trying to simplify a long winded process, and think it may be achievable in MaxScript. Apologies my knowledge of MaxScript (and any programming) is extremely basic.
What I would like to do is convert every material in a scene to a VrayOverrideMtl, keeping the existing material in the base slot. Then apply a vrayMtl to the Reflect mtl slot, and change the diffuse color of this vrayMtl to black. I'd need the script to ignore certain objects, which could be defined as a selection, layer, etc. However thinking about this I could "cut and paste" the objects I don't want to be affected, but if it could be done through scripting then that would be great.
My main problem is that I can't see how to change the material type through scripting. I can see how it works using the listener, and manually assigning the new material type, but that's not really how I think it should work. Ideally I think I should be using something like this -
for mat in scenematerials do
if iskindof o.mat VrayOverrideMtl do
SCRIPT TO CHANGE MATERIAL TYPE, ETC
Any help would be really appreciated.
Thanks,
Dean
Try this function. If fn argument"selectedObjs" is set to "on" then fn works on selected objects only or if is set to "off" then on scene materijals. Also this fn respect instanced materials.
fn convertToOverideMtl selectedObjs: =
	local mtls = #()
	fn checkmat mtl arr = (mtl != undefined and not iskindOf mtl VrayOverrideMtl and findItem arr mtl == 0)
	if selectedObjs then
		if selection.count > 0 do (for o in selection where (checkmat o.mat mtls) do append mtls o.mat)
		for m in scenematerials where (checkmat m mtls) do append mtls o.mat
	if mtls.count > 0 do for oldMtl in mtls do
		newMtl = VrayOverrideMtl name:(oldMtl.name + "_Override") baseMtl:(copy oldMtl) reflectMtl:(vraymtl diffuse:black)
		for n in refs.dependents oldMtl do case of
			(isvalidnode n and n.mat == oldMtl): n.mat = newMtl
			(iskindof n material): for i = 1 to (getNumSubMtls n) where (getSubMtl n i) == oldMtl do setSubMtl n i newMtl
After you run fn for the first time use belowe code
convertToOverideMtl selectedObjs:on -- if you want to consider only selected objects
or this line
convertToOverideMtl selectedObjs:off -- this will works on scenematerials
