I have a maxscript file which reads an ascii file (XYZ COORDINATES) generating from LIDAR DATA and converts the ascii file into 3dsmax cylinders 100m high at the XYZ COORDINATES. This script worked fine until MAX 2018. With 2019 there is an issue which needs resolving. The issue is that the script draws the cylinders not at the correct XYZ; ie they are shifted.
Please let me know if you can help and how much it will cost. I will send you the script file upon request.
Conversion of existing maxscript file
By JOSEPH PACE · 2019-06-14
I have sent you PM.
