Hello. Basic question (but i can't find it on the internet)
I have a shape with 2 splines: /sp1v1--sp1v2/ /sp2v1--sp2v2/.
Now i want to connect sp1v2 with sp2v1.
something like this:
select $MyShape
subObjectLevel = 1
splineOps.startConnect (1,2) (2,1)
can someone give me a hit? tnx
Comments (8)
follow-up question (i have a problem selecting things)
It works untill the last line.
But "$GB1#(2)","(3 2)", "the-other-spline" gives me errors.
Can you tell me whats wrong
(I have the book "maxscript essentials", but these essential-syntax things are missing..)
tnx.
if you want to boolean shapes then you're in trouble.
damn, sure :))
fresh max versions have shape booleans
yes, tnx a lot Miauu.
my shape is complexer as in the startpost, but i think i can adjust your code for that.
AddAndWeld is a global shape operation. It will weld any end knots that are in tolerance distance from each other. You probably better use splineOps.weld to weld only the selected knots
Tnx Jahman.. if i run the script a second time i'm having trouble. Ill try your solution.
