I found this maxscript that loads sequences and displays them in a window in real time, for animators is a very useful tool.
I wish it could be modified to be able to connect the spinner with timeslider and in that way drag the timeslider and that the sequence changes automatically.
follow the instructions that are here to achieve it and do not update the images on screen.
http://www.scriptspot.com/forums/3ds-max/general-scripting/currenttime-o…
try(cui.UnRegisterDialogBar rlt_preview) catch()
try(destroyDialog rlt_preview) catch()
global Thepos1=[0,0]
global mousedd1=false
local allFiles1 = #()
local shu=0
local last_path = ""
local bofang=true
local shijian=0
local shudu=1
rollout rlt_preview "Sequence Viewer" width:350 height:350
bitmap img_preview "texture preview" pos:[6,6] bitmap:(bitmap 340 265 color:black)
slider sld1 "0000" pos:[6,275] width:335 height:44 range:[1,100,1] type:#integer ticks:0 border:false
button btn1 "Play" pos:[140,316] width:78 height:25
button btn2 ">>" pos:[224,316] width:25 height:25
button btn3 "<<" pos:[110,316] width:23 height:25
button btn4 "Load" pos:[21,317] width:39 height:24
button btn5 "x" pos:[70,317] width:25 height:25 toolTip:"¹Ø±Õ"
Timer clock "testClock" pos:[310,316] width:24 height:24 interval:1
Timer clock1 "testClock" pos:[310,316] width:24 height:24 interval:1000
slider sld14 "" pos:[263,320] width:79 height:25 range:[1,40,1] type:#integer ticks:0 border:false
label lbl3 "Speed" pos:[275,308] width:52 height:18
on rlt_preview lbuttondblclk g11 do
DestroyDialog rlt_preview
on rlt_preview lbuttonup pos1 do
mousedd1=false
on rlt_preview lbuttondown pos1 do
mousedd1=true
Thepos1=pos1
on rlt_preview mousemove pos1 do
( if mousedd1==true Then
(SetDialogPos rlt_preview (mouse.screenpos-Thepos1))
on rlt_preview open do
on btn5 pressed do
destroydialog rlt_preview
on sld1 changed val do
if last_path!="" do
shu=val
rlt_preview.img_preview.bitmap = openBitMap allFiles1[val]
on sld4 changed val do
shijian=val
on btn1 pressed do
if last_path!="" do
if bofang==true then (bofang=false )else(bofang=true )
if bofang==true then (btn1.text="Play" )else(btn1.text="Stop" )
on btn2 pressed do
if last_path!="" do
if shu
shu=shu+1
shu=shu-allFiles1.count+1
sld1.range=[1,allFiles1.count,shu]
rlt_preview.img_preview.bitmap = openBitMap allFiles1[shu]
on btn3 pressed do
if last_path!="" do
if shu >1 then ( shu=shu-1)
else (shu=allFiles1.count)
on btn4 pressed do
local path = getSavePath caption:"" initialDir:last_path
if path == undefined then
path = ""
else(
last_path = path
DestinationPath_STR = path as string
get_path = DestinationPath_STR + "\\"
allFiles1 = getFiles (get_path+"*.png")
allFiles1 =allFiles1+ getFiles (get_path+"*.jpg")
rlt_preview.img_preview.bitmap = openBitMap allFiles1[1]
sld1.text= allFiles1.count as string
sld1.range=[1,allFiles1.count,1]
on clock1 tick do
lbl3.text="Speed"
on clock tick do
sld1.text=shu as string
shijian=shijian+1
if shijian==shudu do
shijian=0
if bofang ==false do ( if shu
shu=shu+1
)else(shu=shu-allFiles1.count+1)
rlt_preview.img_preview.bitmap = openBitMap allFiles1[shu] )
on sld14 changed val do
(shudu=val
shijian=0
-- on rlt_preview close do
-- on rlt_preview resized size do
-- img_preview.width = rlt_preview.width
-- img_preview.height = rlt_preview.height
createdialog rlt_preview style:#( #style_minimizebox)
