Combine Two Arrays
By Branko Živković · 2014-03-14
Let say we have two array with same items count.
arr1 = #("a","b","c","d","e")
arr2 = #(1,2,3,4,5)
Which will be the easy way (sort code) to combine these 2 and get this output
#("a", 1, "b", 2, "c", 3, "d", 4, "e", 5)
Comments (14)
3dwannab
Thanks for the discussion guys,
I've one but I think it's not in the order you want this just joins arrays after each other. Quite simple but it could be of use to someone passing through.
array1 = #("a","b","c","d","e")
array2 = #(1,2,3,4,5)
array3 = #("this","works","a","treat")
array4 = #("3dsMax","crashes","too","much")
fn combine_4_Arrays arr1 arr2 arr3 arr4 =
	tempArr = copy arr1 #nomap
	join tempArr arr2
	join tempArr arr3
	join tempArr arr4
newArr = combine_4_Arrays array1 array2 array3 array4
#("a", "b", "c", "d", "e", 1, 2, 3, 4, 5, "this", "works", "a", "treat", "3dsMax", "crashes", "too", "much") -- > returned array
Clément Plantec
Hi Barigazy
I liked the idea so I tried it but I got an error. The object properties are not as string but still as integer so the dotNet function isn't working...
Here is the code I have:
fn combineArray arr1 arr2 =
	testArray1 = #()
	for i = 1 to arr1.count do join testArray1 #(arr1[i],arr2[i])
	testArray1
fn printer propArr varArr filename: =
	testArray2 = combineArray propArr varArr
	(dotnetclass "System.IO.File").WriteAllLines filename testArray2
b = createInstance Box
props = #()
vals = for p in getPropNames b collect
	append props (p as string)
	getProperty b p
printer props vals filename:@"c:\temp\test.txt"
And here is what I get in the listener:
combineArray()
printer()
Box
#(25.0, 25.0, 1, 25.0, 1, false, 1, false)
-- Error occurred in printer(); filename: D:\Travail\Projets\3D Studio Max\Script\Sugarz Tools\scripts 2014\Test Barigazy\combine_two_arrays_02.ms; position: 286; line: 12
--  Frame:
--   filename: "c:\temp\test.txt"
--   varArr: #(25.0, 25.0, 1, 25.0, 1, false, 1, false)
--   propArr: #("height", "length", "lengthsegs", "width", "widthsegs", "mapcoords", "heightsegs", "realWorldMapSize")
--   testArray2: #("height", 25.0, "length", 25.0, "lengthsegs", 1, "width", 25.0, "widthsegs", 1, "mapcoords", false, "heightsegs", 1, "realWorldMapSize", false)
-- Unable to convert: 25.0 to type: String
By the way, my pseudo isn't SugaRi, just SugaR (it wasn't free to use for registering and I didn't changed it afterwards :)
You might wonder what purpose has this function.
Well.. for example we can easely print some object props to external file.
	array = combineArray propArr varArr
	(dotnetclass "System.IO.File").WriteAllLines filename array
Example:
props = #()
(getProperty b p) as string
#3 solution by SugaRi
array = deepcopy arr1
for i = 1 to arr1.count do insertItem arr2[i] array (i*2)
array
#1 solution
This solution represents longest and slowest version.
int = 2 ; e = 1
number = arr1.count*2
do
insertItem arr2[e] arr1 (int)
int+=2 ; e+=1
while int <= number
arr1
Reply to Branko Živković
#2 solution
Easy way
array = #()
for i = 1 to arr1.count do join array #(arr1[i],arr2[i])
array
Clément Plantec
Not sure if it's a good or fast solution but it works:
testArray = arr1
	j = i*2
	insertItem arr2[i] testArray j
testArray
Reply to Clément Plantec
This solution can works but first thing first:
If you want to prevent changes of arr1 you need to use "deepcopy" fn ei.
testArray = deepcopy arr1
Not need to use "j" variable here just
insertItem arr2[i] testArray (i*2)
"insertItem" fn is slow for big arrays.
Clément Plantec
Ok good thing to know about the copy/deepcopy
About the "j" variable, It's just easier for me to work with variable like this when I write some code, like that it's easier to modify the expression afterwards if needed, since I have a better visibility of the expression in the code :)
Then when the code is working, I try to get rid off all this kind of useless variable to optimize the code.
I fixed previous code. I just forgot to convert value to string
(getProperty b p ) as string
If you have another idea for usage or any array combo post here and we can continue disscusion.
Cheers!
Clément Plantec
I don't have any for the moment, but come back when I will :)
Otherwise, I'd liked to get a bit of improvement of what you've done here:
for now, you print each element of the combined array into separate lines in the txt file, how would you do to print all of the array elements in only one line,with some punctuations, units and the object name at the begining.
For summarize a bit, something like that:
Box01: height: 25cm, length: 25cm, etc...
