Color picker RGB values
By Script_Butler · 2012-04-11
Hi all.
I'm trying to write a script that manipulates colors when using gamma 2.2.
Basically I want to have a color picker ("old") so the user can choose a colour and one next to it ("new") that is the result of the following equation.
new=255*((old/255)^2.2)
This will make the RGB values correct when using gamma.
Any help on this would be much appreciated.
Cheers.
Panteleev Sergey
It isn't very precise, unfortunately. Dunno how to make it work better.
try (destroydialog X ) catch ()
rollout X "" width:100
	colorpicker cp  "" color:black across:2 width:51 pos:[-2,2] offset:[0,0]
	colorpicker cp2 "" color:black width:51 pos:[47,2] offset:[0,0]
	spinner gamma "Gamma " range:[0.0,1e6,2.2] fieldwidth:40 align:#center
	fn setColor2 =
		local g = gamma.value as double
		local clr = cp.color
		v255 = 255.0 as double
		cp2.color = [ v255*((clr.r/v255)^g), v255*((clr.g/v255)^g), v255*((clr.b/v255)^g) ] as Color
	fn setColor1 =
		local g = 1.0 / (gamma.value as double)
		local clr = cp2.color
		cp.color = [ ceil (v255*((clr.r/v255)^g)), ceil (v255*((clr.g/v255)^g)), ceil (v255*((clr.b/v255)^g)) ] as Color
	on cp  changed clr do setColor2()
	on cp2 changed clr do setColor1()
	on gamma changed val do setColor2()
createDialog X
Reply to Panteleev Sergey
igamaximus
Practically perfect !
Hey Sergey,
perfect mate, this is practically perfect again!
I just tested on RGB value of 255,229,191 and your beautiful tool gives 255,201,134 which is just 1 step off in Blue channel (255,201,135 is perfectly accurate) and it should be impossible to tell the difference. Thank you so much, again and again for your valuable help !
I would like to ask you something, can you please give me your e-mail?
igamaximus
Hi mate,
this one is very old but right now i need exactly the same thing. Have you ever found solution for this in this form you have asked for, or maybe as some color converter tool that works with colors exclusively (without using textures and gamma settings in them) ?
Thank you
