close rollout
By titane357 · 2020-06-19
I have two rollout.
I want to close them. So I use :
if (RF.dialogBar == true) do
			cui.UnRegisterDialogBar RF
			closeRolloutFloater RF
if (RFB.dialogBar == true) do
			cui.UnRegisterDialogBar RFB
			closeRolloutFloater RFB
It works when I use script, but not with macroscript.
Any idea ? Thanks.
Panteleev Sergey
You can make a single global struct that holds information about all of your rollout floaters defined in various scripts
and then you can access all of them using single global variable
example:
-- if structure already exists then just call titane357.AddRolloutFloater whenever new rollout floater is created (titane357 structure must be created only once)
global titane357 =
	local owner
	struct titane357
		rollout_floaters = #(),
		fn CloseRolloutFloater rollout_title =
			for i = rollout_floaters.count to 1 by -1 where (stricmp rollout_title rollout_floaters[i].title) == 0 do
				try closeRolloutFloater rollout_floaters[i] catch()
				try cui.UnRegisterDialogBar rollout_floaters[i] catch()
				deleteItem owner.rollout_floaters i
		fn AddRolloutFloater floater =
			if isKindOf floater RolloutFloater do append rollout_floaters floater
		on create do owner = this
	titane357()
-- define some rollout
rollout X ""
	button btn "btn"
-- make a floater
my_floater = newRolloutFloater "titane357 floater" 300 220
addRollout X my_floater
-- register this floater in titane357 structure
titane357.AddRolloutFloater my_floater
-- print all registered floaters
format "Floaters: %\n"  titane357.rollout_floaters
sleep 1.0
-- Now close and unregister particular floater. This can be done from any macro or script since titane357 is a global variable and all of its properties and methods are public
titane357.CloseRolloutFloater "titane357 floater"
-- floater's gone
titane357
oookey...I manage to do it
oookey...
I manage to do it :
Rollout declared as global.
And made a macroscript to run my script (as for .mse).
It works. If anybody can explain I would be happy ! :-)
I add to my script "try" and "catch" because if one (or both) rollout isn't active I got error.
