Cloned object single color
By Mrjacks2o · 2009-11-13
Hi i cant seem to get the cloned source objects all the same color for example i want all the cloned objects to be red this is the code if anyone can help me out i will appreciate it thanks
JM_float = NewRolloutFloater "JM" 120 400
fn fn_bs_img str1 = (#(getdir #scripts+"\3DJM\\"+str1 , undefined, 1, 1, 1, 1, 1))
local copyState=1,sourceObj,destinationObj
fn Align souCopy desNormal pos =
worldUpVector = [0,0,1]
rightVector = normalize (cross worldUpVector desNormal)
upVector = normalize ( cross rightVector desNormal)
theMatrix = matrix3 rightVector upVector desNormal Pos
souCopy.transform = theMatrix
fn CopySource numCopies=
case copyState of
1:
souCpy = for i = 1 to numCopies collect(copy sourceObj)
2:
souCpy = for i = 1 to numCopies collect(instance sourceObj)
default:
souCpy = for i = 1 to numCopies collect(reference sourceObj)
return souCpy
rollout Param "Parametershgh"
pickButton sourcePikBtn "Source" width:75 autoDisplay:true
pickButton destnationPikBtn "Destination" width:75
checkBox vertexChkBox "Vertex" checked:true
checkBox polygonChkBox "Polygon"
group "Copy option"
radioButtons copyOption labels:#("Copy", "Instance", "Reference") align:#left default:1
on sourcePikBtn picked sObj do
if sObj != undefined then
sourceObj=sObj
on destnationPikBtn picked dObj do
if(sourceObj != undefined) and (not isDeleted sourceObj) then
if(vertexChkBox.state == true or polygonChkBox.state == true) then
if dObj!= undefined then
destinationObj=dObj
If ((classOf destinationObj) == Editable_poly) then
if (polygonChkBox.state == true) then
numPolygon = destinationObj.getnumfaces()
Source =CopySource numPolygon
for i = 1 to numPolygon do
faceCentre= polyOp.getFaceCenter destinationObj i
faceNormal = polyOp.getFaceNormal destinationObj i
Align source[i] faceNormal faceCentre
if (vertexChkBox.state == true) then
numVertex = destinationObj.getNumVertices()
source =CopySource numVertex
editNormalsModifier=edit_Normals()
addModifier destinationObj editNormalsModifier
setCommandPanelTaskMode #modify
destinationVertex = #{}
destinationNormalIds = #{}
for i = 1 to numVertex do
select destinationObj
destinationVertex = #{i}
destinationObj.edit_Normals.convertVertexSelection &destinationVertex &destinationNormalIds
normalArray = destinationNormalIds as array
firstNormalValue = destinationObj.edit_Normals.getNormal normalArray[1]
vertexPos= polyOp.getVert destinationObj i
Align source[i] firstNormalValue vertexPos
deleteModifier destinationObj(editNormalsModifier)
messageBox "Select only Editable poly object" title:"Error"
messageBox "Select Vertex or/and Polygon" title:"Error"
messageBox "Select Source Object" title:"Error"
on copyOption changed State do
copyState=State
addRollout Param JM_float rolledUp:False
if you talk about wirecolor:
fn CopySource numCopies = (
	case copyState of
	souCpy.wireColor = red -- add this to your fn
	souCpy
