Checkboxes Maxscript
By JokerMartini · 2010-12-05
How can i make the button on top toggle all checkboxes to either all be true or alll be false disgarding what their current checkstate is.
Like a toggle button.
rollout test "test"
button btnCheck "Check"
checkbox ckbx1 "Stuff" checked:false
checkbox ckbx2 "Option" checked:true
checkbox ckbx3 "Anything" checked:true
checkbox ckbx4 "Junk" checked:false
on btnCheck pressed do
createDialog test 150 140
3dwannab
This is how I've been doing it lately
First name your buttons internal name something that makes sense. If it's for affecting geo then put geo in there and mat for material so you can matchpattern of the control and turn it off depending on your button name.
Something like this:
fn collectControl_fn = /* collects only controls that can be enabled or disabled */
	mappablecontrols_ar = for ctrl in yourrolloutnamehere.controls where classof ctrl != GroupStartControl AND classof ctrl != GroupEndControl collect ctrl
collectControl_fn ()
for ctrl in mappablecontrols_ar where matchPattern ctrl.name pattern:"*geo*" do ctrl.enabled = false
Or use this to avoid problems with checkbox names:
rollout test "test"
	checkbox ckbx_2 "Option" checked:true
	checkbox ckbx_3 "Anything" checked:true
		for aControl in test.controls do
			case classof aControl of
				CheckBoxControl: aControl.state = not aControl.state
stenionet
How can we make the
How can we make a Checkbutton turn off when we click in other tool?
Sorry. I post this in the wrong Topic.
Budi Gunawan
You can create a function to shorten the writing on this case, such:
rollout test "test"
  local state = true --choose false or true as start
  -------------------------------- button
  -------------------------------- function
     fn checked_all boolean =
       ckbx1.checked = boolean
       ckbx2.checked = boolean
       ckbx3.checked = boolean
       ckbx4.checked = boolean
  -------------------------------- execute
          state = not state -- make vice versa
          checked_all state
Reply to Budi Gunawan
Vojtech Cada
Or you can just collect the checkboxes on dialog creation and check them en masse without having to rewrite the function every time you add or remove a checkbox:
rollout test "test"
  local checkboxes
          checkboxes.checked = state
	on test open do
		checkboxes = for c in test.controls where matchPattern c.name pattern:"ckbx*" collect c
Or you can only use "ckbx.state = true"
lol.. my maxscript knolowedge is pretty basic.. so i dont usually use functions and complex commands
rollout test "test"
 	ckbx1.state = true
 	ckbx2.state = true
	ckbx3.state = true
	ckbx4.state = true
