i made this small rollout to test
how i can make an action base on a checkbox.
my goal is to press the button and max will print
"yes" if the checkbox is checked
or "no" if its not.
i keep getting "no"...
what have i miss?
try(destroyDialog rlt_boxer)catch()
global rlt_boxer
rollout rlt_boxer "boxer"
button btntest "Test" across:1
checkbox myCheckBox "myCheckBox" across:1
on btntest pressed do --print yes if checkbox is true or no if false
if myCheckBox == true then
print "yes"
print "no"
) --end of btntest
on myCheckBox changed theState do
print ("myCheckBox-" + theState as string) -- print the state on mycheckbox
) -- end od checkbox
) -- end of rollout
createDialog rlt_boxer 150 50
Also to post properly your code next time see this post
http://www.scriptspot.com/forums/3ds-max/general-scripting/kredka-strike…
Simply use this
try(destroydialog ::rlt_boxer)catch()
print (if myCheckBox.checked then "yes" else "no")
