hey Folks,
Im working on a bigger Script right now and need to check for vertices if they are selected. I would love to stay in the Editable_Poly Environment. To be concrete, I try to iterate through this :
for refVIndex=1 to refObj.GetNumVertices() by 1 do(
)--but my mesh is big so this is way to time consuming. So i try to find a way to iterate through all my selected Vertices. But i also use my refVIndex to create vertices in order at some part in the script so simply using a function which differs in structure will create bad results.
Any help would be appreciated
Greeting EliDerDeli
Comments (10)
there's no difference in performance when we need to do a couple of these checks
here's a little test
checks: 4
Time: 0.002sec. Mem: 320L
Time: 0.001sec. Mem: 576L
checks: 16
Time: 0.005sec. Mem: 1088L
Time: 0.003sec. Mem: 1088L
Time: 0.004sec. Mem: 2112L
checks: 64
Time: 0.016sec. Mem: 4160L
Time: 0.007sec. Mem: 4160L
Time: 0.01sec. Mem: 8256L
checks: 256
Time: 0.06sec. Mem: 16448L
Time: 0.026sec. Mem: 16448L
Time: 0.037sec. Mem: 32832L
checks: 1024
Time: 0.254sec. Mem: 65600L
Time: 0.14sec. Mem: 65600L
Time: 0.188sec. Mem: 131136L
checks: 4096
Time: 1.068sec. Mem: 272816L
Time: 0.597sec. Mem: 272816L
Time: 0.806sec. Mem: 542136L
So, in this case everything is personal coding style. :)
If I understand you correctly you want to know if a vertex with certain index is among selected vertices. Instead of using a loop use bitarray operations:
Let say that you want to know if vertex 15 is selected.
there's no need to find intersection
Is this work for two or more verts that have to be checked if they are selected?
for multiple indexes I'd check it like this
Is there any benefits to use "-" instead of "*"?
.numberset is slower in general
I know, but sometimes, by habit, I use .numberset. :)
Perfect thank you very much, that will help a lot :)
