Check my algorithm error ?
By Alex · 2013-05-03
Hey !
I've made a algoritm but someone can say me if I've some error In my algorithm
And say me if it's possible to export first : the standart Building and after the Destroy building ... thanks for your help !
---------------- DECLARATION DES VARIABLES ----------------------
			exportfolderASE = maxfilepath + "ASE\\"
			exportfolderGR2 = maxfilepath + "GR2\\"
			exportfolder3DS = maxfilepath + "3DS\\"
				 -- CREATION DES REPERTOIRES S'IL N'EXISTE PAS -----
				if doesFileExist exportfolderASE  == false do (makedir exportfolderASE)
				if doesFileExist exportfolderGR2  == false do (makedir exportfolderGR2)
				if doesFileExist exportfolder3DS  == false do (makedir exportfolder3DS)
	--------------------- DEBUT ALGORITHME -------------------------
rollout bgaRoll "Lunastra Building Compiler • • •"
	label Help1 "Standard ou détruit ?" align:#center
	button btn_delchilds "Standard" align:#center width:100 height:20
	button btn_delparents "Détruit" align:#center width:100 height:20
	label Help2 "Reset Xform" align:#center
	button btn_xform "Reset Xform" align:#center width:100 height:20
	label Help3 "Mettez votre modèle droit en vous aidant" align:#center
	label Help4 "du repère et de l'outil rotation et cliquez sur Reset Xform" align:#center
	label Help5 "En cas de modification du Reset Xform Merci de relancer l'algorithme" align:#center
	label Help6 "Copyright by Kasimashi tout droit réservé 2013-2014 ©" align:#center
	on btn_delchilds pressed do
		delete (for o in objects where matchPattern o.name pattern:("*2_*") collect o)
			----------------SELECT ALL -----------
			Select $*
			-------------- ATTACH ALL MESH 	--------------
					mtl = #() ; tmp = #() ; fin = #()
					sel = selection as array
					if sel.count == 0 then -- check selection
						messageBox "Erreur lors de l'execution du script s'il vous plait contactez Kasimashi"
					(	-- filter selection
						sel = for i in sel where classOf i == Editable_mesh \
							and i.material != undefined collect i
							messageBox "Aucun Mesh dans la séléction !!! " title:"Attacher les Mesh"
							for i in sel do
								appendIfUnique mtl i.material
							for m in mtl do
								tmp = for i in sel where i.material == m collect i
								append fin tmp
							undo on
								for i in fin do
									trg = i[1]
									deleteItem i 1
									for j in i do
										meshop.attach trg j attachMat:#IDToMat condenseMat:true
			------------------ RENAME MODEL ------------
				$.name = "Model"
				select $Model
			-------------------- WORKING PIVOT + PIVOT ==> RESET XFORM-------------------------
				----$ .pivot = [0,0,0]
				----workingpivot = [0,0,0]
				--resetxform $;
			---------------------- PLACE 0;0;0 -----------------
				$.pos = [0,0,0]
			------------------- SCALE 1/88 FOR FREEWORLD LUNASTRA------------------------
				exportFile (exportfolderASE + (getFilenameFile maxFileName)+".ase") #noPrompt
			-----------------------EXPORT GR2 + 3DS -----------------------
					scale $Model [88,88,88]
				exportFile (exportfolder3DS +(getFilenameFile maxFileName)+".3ds") #noPrompt using:exporterPlugin.classes[1]
				exportFile (exportfolderGR2 +(getFilenameFile maxFileName)+".gr2")
			-------------------------(RECTIFICATION)--------------------
					scale $Model [0.0113636363636364,0.0113636363636364,0.0113636363636364]
					actionMan.executeAction 0 "311"  -- Tools: Zoom Extents All Selected
	on btn_delparents pressed do
		delete (for o in objects where matchPattern o.name pattern:("*2_*") and o.parent != undefined collect o.parent)
			Select $*
							for i in sel do
							for m in mtl do
								append fin tmp
							undo on
								for i in fin do
									trg = i[1]
									deleteItem i 1
									for j in i do
				$.name = "Model"
				select $Model
				---resetxform $;
				$.pos = [0,0,0]
				exportFile (exportfolderASE + (getFilenameFile maxFileName)+"_destroyed"+".ase") #noPrompt
				exportFile (exportfolder3DS +(getFilenameFile maxFileName)+"_destroyed"+".3ds") #noPrompt using:exporterPlugin.classes[1]
				exportFile (exportfolderGR2 +(getFilenameFile maxFileName)+"_destroyed"+".gr2")
	---------------------- FIN ALGORITHME ---------------------------
	on btn_xform pressed do
		for theNode in selection do if (isValidNode(theNode)) do ResetXForm theNode
createDialog bgaRoll 350 195 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
Use MAX UNDO
For example:
exportModelFN
max undo -- the objects is unscaled
-- scale again to desired value
scale $Model [0.88,0.88,0.88]
exportModelFN
You can optimize the script.
	local exportfolderASE = maxfilepath + "ASE\\"
	local exportfolderGR2 = maxfilepath + "GR2\\"
	local exportfolder3DS = maxfilepath + "3DS\\"
	function PutYourNameOfTheFN suff =
			Select $*
			--	instead of select $* you can use
			--	max select all
							for i in sel do
							for m in mtl do
								append fin tmp
							undo on
								for i in fin do
									trg = i[1]
									deleteItem i 1
									for j in i do
				$.name = "Model"
				select $Model
				--resetxform $;
				$.pos = [0,0,0]
				exportFile (exportfolderASE + (getFilenameFile maxFileName)+ suff + ".aes") #noPrompt
				exportFile (exportfolder3DS +(getFilenameFile maxFileName)+ suff + ".3ds") #noPrompt using:exporterPlugin.classes[1]
				exportFile (exportfolderGR2 +(getFilenameFile maxFileName)+ suff + ".gr2")
		PutYourNameOfTheFN ""
		PutYourNameOfTheFN "_destroyed"
	on open bgaRoll do
The exportfolderASE, exportfolderGR2, exportfolder3DS are global in your script. Did you need they to be global? I put them in the rollout, so they are local. Check the Scope of variables in the maxxcript help file for the difference between global and local variables. One of the major rules is to use global variables only when you need them, otherwise use local variables.
Reply to miauu
Alex
:) Thanks for your help !
but how can I scale $Model [88,88,88] and undo to come back with original scale because scale $Model [0.0113636363636364,0.0113636363636364,0.0113636363636364] is not a excact value I want 1/88 scale.
How can I do this ?
Kasimashi
