I can't seem to find a way to check if an object is an instance or not. I know I can use InstanceMgr.getInstances to get the number of instances for the specified object, but it's not what I'm looking for. RefHierarchy.isRefTargetInstanced is more like what I want, except it returns true for every instanced objects, even the "original" one (from which other objects are instanced). Is this normal ? The same goes for references...
Is there a way to get only instanced objects without the original one ?
I hope you'll understand what I mean,
You can consider the original one the one you select first in order to get all it's instances...
For instance objects, there is no "original" one. Everyone is same.
If you want find the first one, maybe ".handle" property can help you
