check if element in multiarray is nan maxscript
By Elias · 2018-05-29
Hi again,
I wanted to know if theres a way to check for multi array elementns if they are nan ?
oV = SelectedVerticeID.pos
pairs = for o in refObj.selectedVerts where not o.pos ==" [-nan(ind),-nan(ind),-nan(ind)]" collect #(length(o.pos-oV), o.index ) --pairs distance and vertexpos
qsort pairs sortByDist --indexes and sorts
print pairs.count
That would be the rough Idear in pseudo Code.
Any help would be great
Greetings
Vojtech Cada
Use bit.isNAN
Panteleev Sergey
maxscript working with values
isKindOf 0x4 Number -- true
isKindOf .5 Number -- true
isKindOf "1" Number -- false
isKindOf ("1" as integer) Number -- true
ps. seems like you ignore mxs reference
Thanks for the Tipp but that doesnt seem to work. [-nan(ind),-nan(ind),-nan(ind)] Is till got values like that when i try to fill my array and check with isKindOf x Number
Greetings Eli
