Hello together,
i wonder if there is a way to check if some objects (lets call them Hotspots) floating around a fixed object are visible to the camera or behind the main object and therefore not visible?
So far i have written (and copypasted some parts) a script (max design 2013) which outputs the Position of the Hotspots relative to the Camerascreen (XY-Coordinates). Now what i need is a Boolean which says if the object is visible at the moment or not.
Is that even possible using only maxscript?
Sincerly Jerod
Hello again,
so far im experimenting with the intersectRayScene feature.
From what i see it is possible to shoot a Ray from the Cameraposition to the position of the Hotspots.
Now i have to detect which objects are hit first.
So if the Ray hits a Hotspot first then the Boolean should turn to 1 (=visible)
if the Static object is hit first, then the Boolean should turn to 0 (=not visible) right?
im not sure how to setup this script...
I don't know is this what you looking for but anyway this is a example how to
collect separately:
"front objects" ei. objects between Hotspot (Yellow sphere "Sphere004") and camera and "behind objects" ei. objects behind hotspot but in front of camera.
This is the fn
In previous example camera object name is "Camera001" and hotspot object "Sphere004". Now to use this fn run the next line
If you want to select "in front" objects or do some operation on these
U can do this :
Or to select "behind objects" :
select objs.behind
Edit:
change the line
to this
I forgot to remove variable :)
