Check if an object has a material (map) that uses Real-World Scale?
By Jens Schmidt · 2017-09-05
Hej guys & gals,
I can´t figure out how to check if a material/sub-material uses a map with "Use Real-World Scale" ticked, is there anyone here with this knowledge?
/ Jens
Panteleev Sergey
collect all instances of StandardUVGen class that depend on any of your material/submaterial
check mxs reference or google for refs.dependents
and then do whatever you like.
this example will enable realWorldScale for all scene textureMaps (not only bitmaps)
(getclassinstances StandardUVGen).realWorldScale = true
btw. note that any third-party texturemaps like vray, corona etc may have this property right in the texturemap, so you may also check these maps for the according property
