Hi, I'm tring to write a script that will access material libraries from different folders (much like Sigershader's VMPP). My first listbox is populated by an array of Material Categories and are defined as such...
MatSections = #()
append MatSections #("Metal","C:\Users\Alex\Documents\3dsMax\materiallibraries\Metal\\")
append MatSections #("Wood","C:\Users\Alex\Documents\3dsMax\materiallibraries\Wood\\")
append MatSections #("Glass","C:\Users\Alex\Documents\3dsMax\materiallibraries\Glass\\")
Which currently works. When I select an item in this listbox, I want the second listbox to be populated with a list of the matlibs that reside in the relevant folder. Here's what I have so far...
on lbx_MatSection selected itm do
MatCatPath = getFiles "((MatSections[objList.selection][2])"+"*.mat")
MatCatFiles = for i in MatCatPath collect ( filenamefrompath i )
lbx_MatCat.items = MatCatFiles
Which doesn't work. I get an error saying "-- Syntax error: at =, expected name". Previously I had a simpler script that just loaded all matlibs from a folder (which worked)...
allMatLibs = getFiles "C:\Users\Alex\Documents\3dsMax\materiallibraries\*.mat"
list = for i in allMatLibs collect (getFilenameFile i)
lbx_MatSection.items = list
But it was too simple for what I need now. Basically I'm trying to get the two bits of code to work together but I'm struggling, so any help would be greatly appreciated. Cheers,
Alex
Brilliant! Cheers for the help guys. Thought it would be a simple syntax issue, also would have helped if I renamed objList.selection to lbx_MatSection.selection! And thanks for the script recommendation Barigazy, looks really useful.
Thanks again.
You mistyped the (, it should be in front of the ":
MatCatPath = getFiles ("(MatSections[objList.selection][2])"+"*.mat")
That line is wrong, isnt it? Why the quotation marks after getFiles? Maybe more like this:
I suggest you to look inside the code where i use fixpath fn to collect some bitmap names into list.Hope this can help
http://www.scriptspot.com/3ds-max/scripts/select-objects-by-bitmaptex
