Hi !
May I ask you (you, all the MXS masters ;)) some things ?
I want to create a ScriptedModifier which changes the wirecolor of the object when it gets selected.
Is that possible with a ScriptedModifier ?
( Omg, my english is quite bad... :( sorry about that, I hope you can read me..)
Done
Hi !
So, the code you gave me works well, after a bit of tweaking I am able to achieve exactly what I wanted.
I'll release the script as soon as Im sure it is clean.
Thanks again miauu :)
Hey ! Thanks a lot for the answer, Im at school right now, I'll look at your code when I come back home.
Thanks again.
You want to change the wirecolor of the object when you select it?
What will be the new color?
Whay you need modifier?
This script will change the wirecolor of selected object.
