Does anyone know if its possible to change the
dl.SelectedIndex = -1
to non editable text and the rest of the indexes to editable ones.
I want 'Press 'Enter' to rename.mse' to be disabled and the rest to be editable text.
if theTopRollout != undefined then (destroyDialog theTopRollout)
--define variables & globals
global theTopRollout -- This is needed so that you can access your dropdownlist from outside of the rollout
coronaVFBDir = getDir #scripts
default_text = "Press 'Enter' to rename.mse"
try destroyDialog theTopRollout catch()
rollout theTopRollout "Top Rollout"
dotNetControl dl_exrHistory "System.Windows.Forms.ComboBox" text:default_text height:20 width:210 pos:[5,5]
fn fn_RefreshEXRList = ( -- collects exrs and sorts them
-- Collect the exrs into an array by paths & name
intfilesArr = coronaVFBDir + "\*.mse"
filesArr = getFiles intfilesArr
if filesArr.count != 0 then (
sort filesArr
latestEXR = coronaVFBDir + filenameFromPath filesArr[filesArr.count]
VFBexrFilenames = for f in filesArr collect (getFilenameFile f) --//Collect all file names in the specified folder directory
) else VFBexrFilenames = #()
dl_exrHistory.items.clear() -- Clears ComboBox list before rebuilding
dl_exrHistory.items.addrange VFBexrFilenames -- Build a new ComboBox list using the view array
-- insertItem "Coronas VFB History:" VFBexrFilenames 1
dl_exrHistory.text = VFBexrFilenames[1]
on dl_exrHistory open do (
fn_RefreshEXRList()
) --Fill on open
on dl_exrHistory DropDown do (
fn_RefreshEXRList()
) --Fill on expanding the list
createDialog theTopRollout 220 70
Thanks very much mate.
Always a joy to get a great answer from you :)
Hey,
try to use DropDownStyle - on dl_exrHistory SelectedIndexChanged do
so on open change style to:
when selection changed (SelectedIndexChanged) change it to
here is a sample:
