Center of Editable Mesh face
By JokerMartini · 2011-07-19
New forum topics are on pause. Signed-in members can reply to existing topics. Contact ScriptSpot if you need help.
I'm trying to loop through an entire mesh finding the point 3 value of the center of each polygon of an editableMesh.
I have found out how to do it for an editable poly but not and editable mesh.
--newPos = polyop.getFaceCenter $ f --EditablePoly
--Editable Polygon Face
numFaces = $.numfaces/2
for f = 1 to numFaces do
newPos = --EditableMesh
print newPos
JokerMartini
Script
I was working on a script for the public and I would like it to work with editableMesh and EditablePoly that was really the only reason.
heh...
Of course the mesh and poly are not the same :) The polygon in epoly may consist of 1, 2 or more faces. Why just not convert your mesh (the original or snapshot) to epoly? Make your life easy.
JokerMartini
Results....
Because the editable mesh is a triangulated mesh the results are not what I was expecting.
If you run this code you'll see.
It's creating twice as many spheres as it needs and they are not at the center of the entire polygon. Should I loop through and for every two spheres create a sphere at the middle distance of the 2 spheres created to get the proper sphere placement at the center of the actual polygon?
--Editable Mesh Face
newPos = meshop.getFaceCenter $ f -- EditableMesh
sphere radius:1 pos:NewPos
print newPos
