I forgot this didn't work, just spent 3 hours setting up materials and on reload they were trashed by the "unknown property" bug.
Any chance this can get fixed ?
http://www.scriptspot.com/3ds-max/scripts/smes-super-material-editor-swi…
It keeps throwing up an error...
"unable to convert: map #1:vrayhdri to type: material"
Then when you reload the scene you get these....
-- Unknown property: "name" in undefined <<
-- Error occurred in matIndex loop; filename: C:\Users\xxx\AppData\Local\Autodesk\3dsMax\2015 - 64bit\ENU\usermacros\Medit Tools-SMES.mcr; position: 2852; line: 76
-- Frame:
-- matIndex: 6
-- called in matPageIndex loop; filename: C:\Users\xxx\AppData\Local\Autodesk\3dsMax\2015 - 64bit\ENU\usermacros\Medit Tools-SMES.mcr; position: 2852; line: 76
-- Frame:
-- matPageIndex: 1
-- newNode: dotNetObject:System.Windows.Forms.TreeNode
-- called in loadMatPages(); filename: C:\Users\xxx\AppData\Local\Autodesk\3dsMax\2015 - 64bit\ENU\usermacros\Medit Tools-SMES.mcr; position: 2972; line: 82
...etc...etc...
It's much quicker than using slate, easy fix? rewrite? dodo ?
moochus grassy arse :)
