Calling .Net functions
By WillyWonka · 2010-11-10
I'm trying to write a script that does a SHA1 check on a file and I understand the .Net calls that I need to call but for the life of me I can't get it working in maxscript. Can anyone help me finish it?
The first problem is the file delme#.txt never gets closed. I'm pretty sure I need to call stream.Close() but I can't get it to work.
The second is running byte[] = hashClass.ComputeHash(fileStream, FileMode.Open)
How do I store a byte array in maxscript?
fn SHA filename =
	if doesFileExist filename then
		fileMode = dotNetClass "System.IO.FileMode"
		print (fileMode.Open as string)
		stream = dotNetObject "System.IO.FileStream" filename fileMode.Open
		hashClass = dotNetClass "System.Security.Cryptography.SHA1CryptoServiceProvider"
		hash = hashClass.ComputeHash stream
		-- Try unsucessfully to close the stream
		showMethods stream
		dotNetObject "System.Security.Cryptography.SHA1CryptoServiceProvider.Close"
		dotNetObject "System.IO.FileStream.Close"
SHA "c:/DelMe6.txt"
fastcg
fn GetSha filepath =
if doesFileExist filepath do
stream = dotNetObject "System.IO.FileStream" filepath (dotNetClass "System.IO.FileMode").Open
hashClass = (dotnetclass "System.Security.Cryptography.HashAlgorithm").Create()
hash = hashClass.ComputeHash(stream)
stream.Close()
return (dotnetclass "System.BitConverter").ToString(hash)
GetSha @"E:\readme_1.txt"
Mirko
The problem is, you're creating a dot.Object with a close method... to me that looks totally weird.
Since you want to perform the close-method on the existing stream use "stream.close()" to close this class-instance.
