Im wondering if there is an easier way to go through my UI variables instead of doing it one at a time. For example, I have 40 text boxes and I named the boxes by increasing number, text1, text2 ... text39, text40. Instead of writing out 40 lines of code to get the information in every text box, I was hoping to do something like
for f=1 to 40 do (
append textArray textf.text
Ive tried ("text" + f as string) as object
That didnt work. Is this even possible in maxscript or am I stuck working with a very long script?
this is what you need right?
Thats it
Thanks. Works perfectly
Create new empty scene, create 5 boxes and execute this code
In the listenre will be printed 5
Do you have objects, which names start with "textbox". If you don't have it, the result from
will give you 0.
If your objects name are:
01_textbox_001
02_textbox_002
then to get all objects with string "textbox" in the names you have to use
I can only seem to get that to work with modeling objects.
print $textbox*.count gives me 0
Soemthing like this:
