callbacks renamed layer
By fajar · 2012-07-05
I had this dialog
	global test
	rollout test "Untitled" width:162 height:48
		dropDownList ddl_Laylist "DropDownList" pos:[5,3] width:154 height:40
		fn MyContainedLayer =
		ddl_Laylist.items=#()
		layerContent= #("0 (default)") + sort (for layer = 1 to layerManager.count - 1 collect (layerManager.getLayer layer).name)
		ddl_Laylist.items=layerContent
		on test open do
			MyContainedLayer()
			callbacks.removeScripts  id:#lay_List03
			callbacks.addScript #layerCreated "test.MyContainedLayer()" id:#lay_List03
			callbacks.addScript #layerDeleted "test.MyContainedLayer()" id:#lay_List03
			callbacks.addScript #nodeLayerChanged "test.MyContainedLayer()" id:#lay_List03
	createdialog test
the callbacks layer created n layer deleted is workin fine but when I try to rename the layer from layer manager, its seems not update in my ddl_laylist items as well, but i already add node layer changed callbacks, did something wrong with my script !? please I need some suggestion to make my script working.
best regard
fajar
