Callback when SME is open and closed
By 3dwannab · 2016-09-11
I've got the callback for when SME is open from MSX help and I've tried to reverse engineer it to work when it's closed.
I've never used dialogmonitorops or UIAccessor before so any help would be appreciated.
Code I've got so far:
clearlistener()
DialogMonitorOPS.unRegisterNotification id:#mxs_test_open
DialogMonitorOPS.unRegisterNotification id:#mxs_test_closed
fn SlateCallbackOpen = (
	clearlistener()
	h = dialogmonitorops.getwindowhandle() -- get current popup window
	if UIAccessor.GetWindowText h == "Slate Material Editor" then (
		print "Slate Material Editor is opened"
		print (UIAccessor.GetWindowClassName h)
		print (UIAccessor.GetWindowText h)
	true
fn SlateCallbackClosed = (
	clearlistener()
	if UIAccessor.GetWindowText h != "Slate Material Editor" then (
		print "Slate Material Editor is closed"
	true
-- register dialog monitor callback notificition
dialogmonitorops.registernotification SlateCallbackOpen id:#mxs_test_open
dialogmonitorops.registernotification SlateCallbackClosed id:#mxs_test_closed
-- enable dialog monitor
dialogmonitorops.enabled = true
3dwannab
Got this example now from the help file also..
sme.Open() --Open the SME
theParent = windows.getChildHWND 0 "Slate Material Editor" --get the HWND of the SME
rollout sme_toolbox_rollout "SME Toolbox"
	button btn_nextMap "UP One Level" width:150
	on btn_nextMap pressed do
		theObj = sme.GetMtlInParamEditor() --get the node from the parameter panel
		if theObj != undefined do --if there is a valid node, get its dependents
			local theDeps = for m in refs.dependents theObj where isKindOf m TextureMap or isKindOf m Material collect m
			if theDeps.count > 0 do sme.SetMtlInParamEditor theDeps[1]	--if there were any, select the first one
createDialog sme_toolbox_rollout parent:theParent[1] --create a dialog as child of the SME
But still no moving with SME yet..
Reply to pixamoon
3dwannab
I think I've got a headache looking at this stuff.. I might ask over on some of the other MXS forums :)
Reply to 3dwannab
pixamoon
I'm looking now into WindowShopper by Rotem Shiffman
it read messages of windows in real time and it uses "WndProc"
I'll try to get some function to read windows move only
Reply to pixamoon
pixamoon
oki,
here is it a small script to create callback for external window
it only prints out SME position but you will see general idea how it works
it's based on Window Shopper by Rotem Shiffman:
http://www.monotoneminimal.com/free-tools
take a look in attachment
remember to declare callback as global and release handle when you close your script
global msgSnooper
try(msgSnooper.releaseHandle())catch()
when callback is a global variable you can stop it also when script crash -> msgSnooper.releaseHandle()
ha, and also... with this callback messages you can read when SME is opened or closed :)
