Button UI Control - confirm with enter Key
By paul · 2018-05-17
Hi, how can I send a event by pressing the [Enter] key on the keyboard, instead of using:
on pressed do
on rightclick do
thx
M Lup
1. Use a macroscript.2. You
1. Use macroscript.
2. You can use ahk script to send your event.
paul
to a button.
Reply to paul
Panteleev Sergey
use dotNetControl
try (destroydialog X ) catch ()
rollout X "" (
	dotNetControl btn "button" text:"SomeButton" height:20
	on X open do setFocus btn
	on btn KeyUp ev do (
		if ev.KeyCode == ev.KeyCode.Enter do format "Pressed Enter\n"
createDialog X
Event to what? To a control in a rollout? To which control - button, checkbox, spinner,...?
Reply to miauu
Taso
I think he means somehow making the enter key be able to be used to press ok (like when you are duplicating objects and the popup appear), perhaps accomplished by a macroscript to apply to that particular shortcut/key... or if Enter cant be used as shortcut, an alternative key
