Is there any way to write this more efficiently?
I commented out what I thought would logically make sense and work but it doesn't.
Help would be greatly appreciated.
rollout rltest "test"
button btnGORender "Go Render" enabled:(classof renderes.production == classof Vray())
on rltest open do
curRen = renderers.production -- Render Check
theRenderer = Vray()
if (classof curren == classof theRenderer) do -- Vray Renderer
btnGORender.enabled = true
createDialog rltest
--button btnGORender "Go Render" enabled:(classof renderes.production == classof Vray())
check the class
I not use VRay so I'll wrote something like this...
...but you can test in the Listener what this return:
and then just say something like:
where XXX is the class of VR renderer.
For RTTAssist iI use this function to check wich is the active renderer:
function ActiveRenderer =
local renderer = renderers.current
local rendererClass = classof renderer
if rendererClass == Default_Scanline_Renderer then
activeRender = "scanline"
if (rendererClass == mental_ray_renderer) then
activeRender = "mRay"
activeRender = "Unknown Renderer Type"
print activeRender
return activeRender
ActiveRenderer()
