hi all coders
I have found this script to check if DR in Vray is on or off, and now I need this for checking another checkbox...
is it possible to check if psd manager is on or off, too? see: https://c2n.me/3WIDjWd.png
thanks for reply.
best regards
themaxxer
macroScript Leo_Distributed_render_On
category:"Leo_DR"
internalCategory:"Distributed_Render"
tooltip:"Distributed_Render_ON"
buttontext:"DR ON"
on isChecked return (renderers.current.system_distributedRender)
on execute do
renderers.current.system_distributedRender = not (renderers.current.system_distributedRender)
Comments (10)
it works!!!! man thank you very much!
you are my hero. :)
do you make custom script as job?
I have some ideas for my workflow and I search for a good coder...
best regards
themaxxer
Why not. You can find my contacts inside the script
You can add
similar as the prev script had it.
Best regards,
Pixamoon
That's exactly what I did, but it doesn't help to update button state if user delete effect or disable it manually.
There seem no callback for effects, unfortunately. The only way I found is to use when subAnimStructure ... changes on the RenderEffects trackview track. But didn't experiment much.
Just quickly checked here in 2016 and it works (disable / delete effect) but only when I accept changes by closing "Environment and Effects" window or open/close other dialog.
I checked also function from isChecked manually and it works even without closing dialog. So it means isChecked is fired up only if something changes in max Dialogs
thanks jahman
it seems not to work... and can you write it in a separate script?
best regards
themaxxer
Try these to toggle psd-manager effect.
or
thanks jahman
the first one works, didn't tested the second one.
now is it possible to indicate if the button is pushed? like in the Leo DR script.
I would like to donate something if you want. time is money. :)
thanks
themaxxer
Not sure how to correctly update toolbar button state when user adds or removes an effect or enables/disables it manually. Seems like no easy solution exists or I couldn't find one.
