Browse folder
By Alex · 2013-05-11
Hey ! How are you ? :)
Look I've this :
files = getFiles "C:\Users\seven\Documents\3dsmax\FBX\*.max"
I want to create a dialog to looking for the directory I want.
for exemple
My_file => looking for my repertory in a dialog
files = getFiles My_file
How can I do this ?
Thanks for your help
The problem is that variable allFIles that holds all .max files from the selected folder is not "visible" when you press the btn_export. To fix this:
------------ DECLARATION DES VARIABLES ----------------------
			exportfolderASE = maxfilepath + "ASE\\"
			exportfolderGR2 = maxfilepath + "GR2\\"
			exportfolder3DS = maxfilepath + "3DS\\"
			exportfolder3DSMAX = maxfilepath + "3DSMAX\\"
				 -- CREATION DES REPERTOIRES S'IL N'EXISTE PAS -----
				if doesFileExist exportfolderASE  == false do (makedir exportfolderASE)
				if doesFileExist exportfolderGR2  == false do (makedir exportfolderGR2)
				if doesFileExist exportfolder3DS  == false do (makedir exportfolder3DS)
				if doesFileExist exportfolder3DSMAX  == false do (makedir exportfolder3DSMAX)
	--------------------- DEBUT ALGORITHME -------------------------
rollout bgaRoll "Lunastra Building Compiler • • •"
		local allFiles = #()
		button btn_import "Selection du dossier" align:"center"
		button btn_export "Exporter" align:"center"
		checkbox cbxExportOptions pos:[5,10] tooltip:"Display export dialog"
		label lblExportOptions "Export options" pos:[30,10]
		on btn_import pressed do
			dir = getSavePath caption:"Select Folder" initialDir:#images
				 if dir != undefined do
					allFiles = getFiles (dir + "\\*.max")
					print allFiles
		on btn_export pressed do
			theClasses = exporterPlugin.classes
				for f in allFiles do
					loadMAXFile f;
					max select all --select all objects
					mtl = #() ; tmp = #() ; fin = #()
					sel = selection as array
					if sel.count == 0 then -- check selection
						messageBox "Erreur lors de l'execution du script s'il vous plait contactez Kasimashi"
					(	-- filter selection
						sel = for i in sel where classOf i == Editable_mesh \
							and i.material != undefined collect i
							messageBox "Aucun Mesh dans la séléction !!! " title:"Attacher les Mesh"
							for i in sel do
								appendIfUnique mtl i.material
							for m in mtl do
								tmp = for i in sel where i.material == m collect i
								append fin tmp
							undo on
								for i in fin do
									trg = i[1]
									deleteItem i 1
									for j in i do
										meshop.attach trg j attachMat:#IDToMat condenseMat:true
					$.name = "Model"
					$selection.material = meditMaterials[1] --assign standard material
					$selection.wirecolor = black -- assign black color of wireframe
					viewport.SetRenderLevel #smoothhighlights
					exportFile (exportfolderASE + (getFilenameFile maxFileName)+ ".ase") #noPrompt
						-----------------------EXPORT GR2 + 3DS -----------------------
					scale $Model [88,88,88]
					actionMan.executeAction 0 "311"  -- Tools: Zoom Extents All Selected
					saveMAXFile (exportfolder3DSMAX+ (getFilenameFile maxFileName)+ ".max")
					exportFile (exportfolder3DS +(getFilenameFile maxFileName)+ ".3ds") #noPrompt using:exporterPlugin.classes[1]
					exportFile (exportfolderGR2 +(getFilenameFile maxFileName)+ ".gr2")
Reply to miauu
Alex
Works perfect
Thanks !!!! it work perfect !
but what mean ?
Reply to Alex
allFIles is variable.It can be a number(integer or float), a string, name,bitarray,array,etc.
local means tha this variable is visible only for the script and when you close the rollout the variable is deleted fromthe memory.
getFiles returns all files in the given directory as array, so
with:
i define the allFiles to an array
In maxscript this
means array and can contains almost whateveryou want.
Tthis
means bitarray().
Check the maxscript help file formore detailed explenations:
- Scope of variables
- array
- bitarray
When you define a variable in the
on btn_ pressed do
this variable can't be accessed in another event handle, so if you want to access a variable everywaher in the rollout you have to define it as local before any event handles or as a global(check Scope of variables in the maxscript helpfile).
Idon't have max right now(I am at work) but:
try(destroyDialog rol_Browse)catch()
rollout rol_Browse "Browse"
   button btn_browse "Browse"
   on btn_browse pressed do
        print allFiles
createDialog rol_Browse
Reply to miauu
Alex
Thx
Thanks you but I can't find what is false in my script with your browse dialog :s
					print allFiles
					loadMAXFile f;
							for i in sel do
							for m in mtl do
								append fin tmp
							undo on
								for i in fin do
									trg = i[1]
									deleteItem i 1
									for j in i do
					$.name = "Model"
createDialog bgaRoll 350 500 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
