Hello,
Is-it possible to break the pickobject of multiple selection ?
I have a checkbutton with a pickobject (see code)
When I uncheck this button I want this stop pickobject (#escape)
Thanks for your help
on myButton changed state do
if (state == true) then
local objs = #()
num = 1
objs = pickobject count:#multiple
for i in objs do
i.name = (num as string)
num+=1
myButton.checked = false
// HERE THE BREAK ACTION... ???
// I TRY return #escape and lots of things, but nothing works
Then maybe using while will be more short and clear code, like:
Yes thanks, but the problem is the same : the pickobject is active while user break it (by escape button or right click)
Maybe this topic will help:
http://www.scriptspot.com/forums/3ds-max/general-scripting/request-start…
Thanks for response
I see this topic, but this is for pickbutton.
I need to select multiple objects, so this doesn't work.
Any idea ?
