Hi.
I have a road mesh that loops and I need to break the connection between the two last vertices and the two first ones.
I am using this to try to do that:
subobjectLevel = 1
$.EditablePoly.SetSelection #Vertex #{1..2}
$.EditablePoly.breakVerts ()
But it is giving me this error:
-- Error occurred in anonymous codeblock; filename:file.ms; position: 3880; line: 151
-- Argument count error: breakVerts wanted 1, got 0
If I use max interface to selecte those vertices and click on the Break button it will work fine. But I need to do that with script.
Any ideas?
Thanks.
Thanks.
Break Verts
When you using break operation you must specify
the index of selected vert
Try this also
vc = $.numverts$.EditablePoly.SetSelection #Vertex #{1,2,(vc-1),vc}
for v in #{1,2,(vc-1),vc} do $.EditablePoly.breakVerts v
Try with:
