boolean code error
By dussla · 2021-03-06
sorry ~ many ask ~
i made this code too
this is boolean code about selected face
i tested many times
but i dont know error problem well
pls teach again ~~~
bigbox = selection[1]
faces_sel=polyOp.getFaceSelection selection[1];
polyOp.detachFaces selection[1] faces_sel delete:false asNode:true name:"newface"
smallface = copy $newface ;delete $newface
converttopoly smallface
polyop.extrudefaces smallface (polyop.getfaceselection smallface) (-100)
snapMode.active=false
ProBoolean.createBooleanObjects bigbox smallface 2 0 0
ProBoolean.SetPlanarEdgeRemoval bigbox 3
Panteleev Sergey
Try to cap holes of the extracted mesh and flip its normals before performing boolean operations
tested , but still error
i tested~ but still error
pls what problem ?
converttopoly bigbox
select smallface
modPanel.addModToSelection (Cap_Holes ()) ui:on
modPanel.addModToSelection (Normalmodifier ()) ui:on
--boolObj.createBooleanObject bigbox
--boolObj.setBoolOp bigbox 3
--boolObj.SetOperandB bigbox smallface 4 2
Reply to dussla
Panteleev Sergey
I didn't test it on your scene file. Script kinda works on my test geometry, so these errors you're having are most likely geometry/topology/selection dependent. I don't know what you can do about that. As a general rule you'd better stay away from using boolean as long as you can.
These two lines certainly make no sense. First you make a copy of $newface object and then delete $newface object for no reason.
delete $newface
thank you again ~~
Thanks for good advice
The script works fine
But sometimes an error occurs
It doesn’t produce a clean and clean result.
Like you said, it's better not to use it.
Thank you~~
