Bitmap swapping
By sdds · 2016-01-26
Hi all, im a maxscript novice.
Im trying to swap a bitmap image in the ui with a button click. Ive tried calling a function from bitmap filename:. a variable works but not with the buttons.
so far not great:)
fn test1 =
img1 = @"B:\images1.jpg"
fn test2 =
img1 = @"B:\images2.jpg"
rollout _test "test"
bitmap bmp1 "Bitmap" pos:[7,11] width:146 height:121 --filename: --not sure here
button _A "A"
on _A pressed do
test1()
button _B "B"
on _B pressed do
test2()
createdialog _test
any help is appreciated
sdds
Thanks Swordslayer, really appreciate the help!
The underscore is something i picked up from a tutorial. and murge is a typo lol.
I cant seem to get the max file to merge though. Ill look into variable scope.
thanks again
sdds
thanks, that helped a lot!!!
I have another issue trying to fix with string trimming.
the result is pulled into a list box, and i need to remove the .jpg and replace with .max to merge a max file on selection.
_MatItems = GetFiles @"F:\test\*.jpg"
_MatItemsUI = #()
for i = 1 to _MatItems.count do
_MatItemsUI[i] = (filterstring _MatItems[i] @"\") [7]
Rollout _MatImport "Exterior Materials" width:310
bitmap bmp1 "Bitmap" pos:[7,11] width:300 height:300
Listbox _InteriorMats "Materials" items: _MatItemsUI
Button _ApplyMat "Apply Material"
on _ApplyMat pressed do
MurgeFile = _MatItems[_InteriorMats.selection]".max"
mergemaxfile MurgeFile
createdialog _MatImport
Reply to sdds
Vojtech Cada
Basically, aomething like this should do the trick:
_MatItems = getFiles @"F:\test\*.jpg"
_MatItemsUI = for mat in _MatItems collect getFilenameFile mat
rollout _MatImport "Exterior Materials" width:310
	listBox _InteriorMats "Materials" items:_MatItemsUI
	button _ApplyMat "Apply Material"
		local murgeFile = _MatItems[_InteriorMats.selection] + ".max"
		mergeMaxFile murgeFile
createDialog _MatImport
Btw. you have a peculiar choice of variable names, why all the underscores and stuff like murge instead of merge? Get used to using explicit locals, read about variable scope in the reference and fear not and use simple var names ;)
Vojtech Cada
Use the bitmap property instead:
	bitmap bmp1 "Bitmap" pos:[7,11] width:146 height:121 bitmap:(openBitMap @"B:\images1.jpg")
	button _A "A"
	button _B "B"
	on _A pressed do bmp1.bitmap = openBitMap @"B:\images1.jpg"
	on _B pressed do bmp1.bitmap = openBitMap @"B:\images2.jpg"
createDialog _test
