I use MAX 2009, 4Gb memory, Win XP.
Script use in work about 150 bitmap
After start, I get
Bitmap Filter Error
Failed to allocate filter for this bitmap. Not enough memory. This bitmap may render incorrectly
I've read topic
Rendering Preferences> Bitmap Pager.....
But can't adjast them....
Help me
maybe u should use 3dsmax x64bit and windows x64 bit version....it'll maybe solve your problem, maybe its because u use windows xp x86bit, which is cant optimum your memory usage...to prove it open my computer , properties and your memory only readed as 3.25 gb, which is less than 4gb you have. As artist in gfx industry you should started using 64bit windows.
best regard
fajar
