txt +="bitmap yunuss \"yunuss\" pos:[100,80] width:124 height:124 fileName:((getDir #scripts) + \"\\FastMorph\\normal.JPG\")"
how isnt my image normal.JPG showing up in bitmap yunus frame
By yunusbbayram · 2008-06-23
Are you using execute to execue the txt string?
If so, you're missing a couple of \ in you string. It should be:
I don't know what you're trying to do with this, but as a general rule, using execute is not recommended, and should be avoided if possible.
hOpe this helps,
o
