Hi, I'm new to scripting. I setup character and need my bone using rotation constraint with limitation.
Such as eyelid (follow eye's movement but not when it look upward)
Such as finger's root (rotate as finger bends, but not in reversed way as you can see in attached GIF)
I found someone's post, and it said;
if currVal < minVal then minVal if currVal < minVal then minVal else currVal |
So I set my variables,
currval=Parent_RotZ minVal=angleaxis 20[0,0,1] MaxVal=angleaxis 50[0,0,1] |
But it happens to have error on minVal...
Since I'm new to script and rotation is much more complex than movement, I have no idea to proceed...
I really appreciate if someone could help me, thank you.
I could fix it
I should have used DegtoRad. It was such simple.
Now it have become like this;
currval=DegtoRad Parent_RotZ
minVal=DegtoRad 20
MaxVal=DegtoRad 50
else if currVal > maxVal then maxVal
else currVal
