Batch rendering different objects in a scene
By alek3tt · 2011-05-16
Maybe if someone know is it possible to make maxscript like this:
unhide object1
render it (VRay) with all render settings unchanged
hide the object
unhide object2
hide the object
unhide objectN
hide the object
is something like that possible to do in maxscript?
Alex
Thank you very much for sharing this great script!
But what if the each object should be rendered by its own vray camera? Is it a complex task ? )
batch-render-wizard
thanks a lot! i have it already, but i'm looking for a way to render without batch render via MFrender script. Create and name system states, give names for renders, etc. takes a lot of time if you have for an example 500 models to render. )
alek3tt
Thank you, thank you, thank you :)
I really have to learn maxscript :)
br0t
this should do the trick:
	--select all objects you want to render separately and execute the script
	local	outputPath = "C:\Users\YourName\Desktop" --change this path to where your renderings should be placed
	local fileExt = ".png" --change this to any image file type
	renderSceneDialog.close() --close render scene dialog to make changes have an effect
	for s in selection do s.isHidden = true --hide all selected objects
	for s in selection do --loop through selection
		s.isHidden = false --unhide object
		rendSaveFile = true --make sure image is saved to disk
		rendOutputFileName = outputPath + "\\" + s.name + fileExt --create filename
		max quick render --render using the settings from the render scene dialog
		s.isHidden = true --hide object again
	)--end for
It will use the settings you set in the render scene dialog, no matter what renderer used.
Cheers
