Hello everyone !
I need to batch export a lot of MAX files included in many folders (about 100 folders !) to OpenCollada DAE format, and save them into the same folders.
I tried some "batch export" MAXScripts, especially Batch It Max but none does what I want :(.
MASS Batch EXPORTER (http://www.scriptspot.com/3ds-max/scripts/mass-file-exporter) seems to fit the best, but I still can't make what I want.
MY Objective is just to select the folders and the script does it all on his own.
Can someone help me please ? Thank you all
Comments (19)
I also often get this error :/
http://img809.imageshack.us/img809/4954/message6.jpg
you could try my script....cadimport, it has batch exporter tho, altho the version I upload isnt include root folder yet, but the modified one in my house already has it.
http://www.scriptspot.com/3ds-max/scripts/cad-files-importer
This problem is solved fajar thanks to Graph's amazing tool, now take a look to my last post :).
Here is my problem :
I get these messages when I open some max scenes :
http://img543.imageshack.us/img543/3817/message4.jpg
http://img13.imageshack.us/img13/8212/message5f.jpg
As you can see the paths he needs are quite complicated, I can definitely NOT do it for so many files, that are very different from each other :).
The trick is that the .jpg texture and map files have the RIGHT name !
I would like to be able to batch relink automatically these files and set them of course once for all !
I want just to select the MAIN folder containing all the files and the tool diggs and finds up the right files on his own.
Thank you mate !
have you tried http://www.scriptspot.com/3ds-max/scripts/relink-bitmaps ?
Relink Bitmap doesn't really make what I need :s
no need for the previous version, i uploaded the next one :P
You're right, this one works !!
You're right, this one works perfectly !
Thank You So much again !
PS: Should I make a new thread to solve my Texture and Maps Filepaths problems ? Or should I continue on this thread ?(Relink Bitmap doesn't really make what I need).
I think
You should just restore the previous version and simply add a "setVRaySilentMode()" line at the top.
I tried it, it works !
Could you reup the first version please ? I have lost it :s
Thank you
fyi i allready uploaded the new version ;)
and check out this one: http://www.scriptspot.com/3ds-max/scripts/relink-bitmaps
Something is still wrong :/
I have this error :
http://img827.imageshack.us/img827/861/message3.jpg
to fix 1 there are so many tools out there
and problem 2 should be fixed with the new version
Great !
For problem 1 can you show me one that I can use ? Eventually works with Batch It Max?
Fot problem 2 you can fix it with just a setVRaySilentMode() line I believe.
alright
here we are, a little new Tool i call Badger (because it digs it's way through the fileStructures)
http://www.scriptspot.com/3ds-max/scripts/badger
have phun and don't forget the +1 ;)
It Works like a Charm... :) but I still have some Problems:
Hi !
First of all thank you for your quick and efficient help, you're definitely an Expert ! ;)
1- For some (many) files, I have "Missing textures" message, even though the Texture and Map files have the correct names, 3DSMax doesn't load them as the filePaths are saved from other computers.
=> Is it possible to make a tool that also digs around the model files to find the textures and maps folder (and files) himself, without asking me to browse it for each file.
2- Then for some other files, I have 2 Vray version messages that pop up :
http://img7.imageshack.us/img7/9532/message1p.jpg
http://img18.imageshack.us/img18/3227/message2ni.jpg
=> So I have to hit OK and YES for every file.
Thank you again Boss !
so multiple source paths that are all gonna be deepSearched and the files collected, then exported in a selected output format using a selected plugin?!
so you want to give it a root folder and want the tool to dig through the folders, collect the files and continue it's way down the rabbithole and then convert/export the collected maxScenes to dae format?
Yes, But
I just want to be able to select many folders instead of 1 Only like it's actually in the script, then I want OPEN COLLADA DAE format, which is different from the 'classic" Dae from autodesk.
Also, I want to set Destination Paths to be the Source Paths.
Thank you !
Here is the MASS Batch EXPORTER script code.
Maxscript to Batch Export Files to selected Format
Author :Preeth.P.G
Created on 19.04.2011
global SourceDirectoryName_STR = "";
Global DestinationPath_STR = "";
rollout ExportASE "Export MAX Files"
group "Select Source and Destination Path"
label lbl1 "Select File Types :" align: #left
dropdownlist FileTypes_List items:#("ase", "fbx", "3ds", "obj") width:70 pos:[145,20]
edittext SourcePath "Source Max Files Path :" text: "" fieldWidth:270 align:#right pos:[15,50] readOnly:true
button SourceButton "Browse" align:#left width:60 height:20 pos:[430,50]
edittext DestinationPath "Destination Render Path :" text: "" fieldWidth:270 align:#right pos:[15,80] readOnly:true
button DestinationButton "Browse" align:#left width:60 height:20 pos:[430,80]
group "Generate ScreenShots"
button Export_BUT "BATCH Export Files" width:470 height:30
on SourceButton pressed do
SourcePath_Var=getSavePath caption:"Please select the source MAX files folder";
Global SourceDirectoryName_STR = SourcePath_Var as string
SourcePath.text = SourceDirectoryName_STR
on DestinationButton pressed do
DestinationPath_Var=getSavePath caption:"Please select the target Export folder";
Global DestinationPath_STR = DestinationPath_Var as string
DestinationPath.text = DestinationPath_STR
on Export_BUT pressed do
try
if SourcePath.text != "" then
if DestinationPath.text != "" then
MaxFilesinFolder_Var = SourcePath.text + "/*.max";
maxFileList = getFiles MaxFilesinFolder_Var
FileFormatSelected = FileTypes_List.selected
for i = 1 to maxFileList.count do
loadMaxFile maxFileList[i] useFileUnits:true quiet:true
MaxFileName_VAR = getFilenameFile maxFileList[i]
destinationFile = DestinationPath_STR + "\\" + MaxFileName_VAR + "." + FileFormatSelected
if i == 1 then
exportfile (destinationFile)
exportfile (destinationFile) #noPrompt
else( messageBox "Please select a valid Destination path")
)else (messageBox "Please select a valid Source path")
-- Resetting the script Window
SourcePath.text = ""
DestinationPath.text = ""
)catch( messageBox "Unknown Error. Please try Again")
createDialog ExportASE width:500 height:170
