hi.. maybe someone can help me with this one..
i am not figuring out how to use the find item on an array of coordinates..
what i want to do is find the item that have the especific z coordinate, doesnt matter whats the x or y
so i am trying something like this:
_array = #([1,2,3],[4,5,6],[7,8,9])
now i want to find the item with z == 6
i´ve tried
findItem _array 6 -- returns 0
findItem _array [*,*,6] -- Syntax error
thanks
hi
using
is good enough, especially if you like to get all matched indexes. Max's
resurns only the index of the first occurrence of the given value. So, if you remove last line of the next function you'll modify it to return an array of all matched indexes --
May try this one too. It s'd be more faster, i think.
Thank you very much
the first one worked really well
the second it only returned the first occurrence like you said.. but its very good as well
i found a workaround
_arrayZ = #()
for i in 1 to _array.count do append _arrayZ _array[i].z
findItem _arrayZ 6
still apreciated if someone know another way to do it
thank you
